O2 Sensor, One or Two on 99 Civic LX?
Old Jul 30, 2005 | 06:36 PM
courir26@yahoo.com
Guest
Posts: n/a
My daughter has a 99 Civic LX, California Model (LEV I think)?
Does this car have one or two O2 sensors?
She got a CEL, Autozone says their scanner cannot differentiate between
a front or a rear O2 sensor failure.
The front sesnor is about a year old.
Are there front and rear sensors, or is the Auto Zone dude all wet?
The rear sensor price is about $250 (if there is such a thing).
Tom
High Tech Misfit
Guest
Posts: n/a
Re: O2 Sensor, One or Two on 99 Civic LX?
> Tom
I don't know if it has one or two, but if the new front sensor is an
aftermarket unit and not OEM, it could pose problems.
Old Jul 30, 2005 | 07:02 PM
strepto's Avatar
Most Hondas on the USDM market has two O2 sensors after 1995. This is where they introduced OBD2 - and a secondary O2 is part of the OBD2 system. It is located in the end of the CAT - and all it really does is to check that the CAT is working ok. It may be replaced with an O2 simulator - approx 100 usd.
Old Jul 30, 2005 | 07:30 PM
Woody
Guest
Posts: n/a
All OBDII cars have at least 2 O2 sensors. Take it to a service shop or
dealer who can test them as throwing parts at it will get very expensive....
<courir26@yahoo.com> wrote in message
news:1122760657.106566.133130@f14g2000cwb.googlegr oups.com...
> Tom
Old Jul 30, 2005 | 08:49 PM
Elle
Guest
Posts: n/a
There are front and rear sensors. You can go to Majestic's site
http://www.hondaautomotiveparts.com/ , put in the car's info, pull up the
exhaust manifold drawing, and see their location. The front one goes for
about $155 + s/h. The rear goes for about $194 + s/h.
Here's a nice summary description of what each does:
http://www.samarins.com/glossary/oxygen_sensor.html
IIRC, if the rear one fails, you risk destroying the catalytic converter,
which is expensive.
If the front one has failed, you should be seeing other symptoms, like poor
mileage, irregular RPM, hesitation, etc.
Old Jul 31, 2005 | 01:32 AM
SoCalMike
Guest
Posts: n/a
2. one staring you right in the face on the exhaust manifold, and one
after the cat, which is bolted to the exhaust manifold.
they need a new scanner then. IIRC, my code was PO135 primary oxygen
sensor heater circuit malfunction.
primary means top, the sensor in the manifold.
OEM honda, or aftermarket? either way its worth testing the sensor for
continuity. for me, the 2 bottom black wires read 0 ohms, which meant
the heater circuit was dead. or something like that. id bust out the
ohmmeter and helm manual and test em both.
yep, there are. but front=top and rear=bottom
> Tom
Old Jul 31, 2005 | 10:30 AM
courir26@yahoo.com
Guest
Posts: n/a
Thanks all for the good advice. The converter is a good bit closer to
the engine than I thought it would be. I'll get an updated code and
figure out which sensor is the problem.
2nd problem. The hood latch handle broke off in my hand. Did they get
this part from GM?
Tom
> > Tom
Old Aug 2, 2005 | 08:35 AM
Pars
Guest
Posts: n/a
> this part from GM?
My hood latch handle on my 98 Civic also broke. I've become quite adapt at
gripping the leftovers with my thumb and index finger and if that fails,
I've got a little pliers in the door bin.
Pars
> Tom
between
> > > Tom
rwjd
Apr 12, 2024 11:54 AM
stubuzz100
Mar 4, 2012 10:15 PM
leonine
Nov 9, 2006 11:23 AM
Scott Rogers
Aug 19, 2005 06:48 PM
someone
Aug 16, 2005 12:32 AM
