drl gone after hid install..?
Old Jul 24, 2007 | 05:29 AM
FELIXY69's Avatar
i just installed my m-tec hid kit
then i found that the drl is gone and drl light is on...
what did i do wrong .. help
thanks
Old Jul 24, 2007 | 01:12 PM
koolkevin1107's Avatar
sorry we don't have drl's on american cars. But ima take a guess from the knowledge i know:
drl's use the high beam bulb (or in this case, filament) and put it at 40% of its power when the car is turned on. They stay lit all the time. Now the hid's u bought, are they bi-xenon? if they are, then the hid's will light at full power because hid's are not like regular filaments if you send a lower wattage they will light. U need the full 12volt power to run them. Now if you got a single filament (h4 low) then u don't have a bulb hooked up to the terminals on the headlight socket where teh high beams go. This is why u are getting a DRL light malfunction. So i think ur next step is to get your foglights wired up as your DRL's like a lot of canadian owners have done when they switched to hid's. Hope that helps.
Old Jul 25, 2007 | 07:07 AM
FELIXY69's Avatar
yes it is bi xeon.
any instructions of how t make fog light run as drl ?
thanks
mr_RogerWill
Nov 2, 2014 04:57 PM
Mr.Hollow
Sep 1, 2014 07:41 PM
a5sh5te34
Aug 16, 2011 09:30 AM
aznbigman
Jan 11, 2009 09:27 PM
fitster
Jun 6, 2008 04:24 AM
