View Single Post
  #2 (permalink)
Old 10-02-2007, 10:03 AM
DynamicFit's Avatar
DynamicFit DynamicFit is offline
DynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to liveDynamicFit relies on Rep Points to live
I have a Mugen short shifter and I love it, but the only thing about it is that does cost a cool 220 bucks. I've also talked to the guys at H-Fit.com and their short shifter kit is going for like $75 and also looks to be a really solid kit. I actually thought there were some things about it that I liked better. The Mugen short shifter sits lower and provides a pretty good amount of throw reduction without sacraficing the ease of changing gears like the stock setup. The H-Fit.com shifter kit retains the stock height (if you are someone who has difficulty pushing the shifter in 5th, either because of short arms or long legs) and increases the notchiness in the shifter feel. The notchiness is good if you're looking for a more positive shifter feel. I also do believe that they are going to be offering it with a shifter as part of their kit. After discussing the installation of the Skunk2 short throw shifter with the H-Fit guys, I would say that you should definitely not got that kit, since it requires a screw placed at an angle screwed against the ball joint of the shifter in order to hold its position. My $0.02.
