Racing A place to discuss upcoming and past Fit racing events.
Wheels for stock-class auto-x...?
Old Oct 9, 2007 | 06:45 PM
Skimmer's Avatar
I'm planning to run my Fit Sport in my local region's H Stock autocross class. I have some experience in autocross and want to be competitive. So I plan to run R-compound tires, so I need a spare set of wheels to mount them on.
My question is, has anybody yet found a reasonably priced lightweight wheel that will satisfy the stock-class rules AND work on the Fit?
I've been searching around quite a bit and the options are limited due to the deep offset on the stock rims. The rules say the wheels must be the same dimensions as stock with no more than 1/4" of additional offset compared to stock (or no more than about +49mm total offset, since the stock offset is +55).
And I'm on a budget.
So basically I'm looking for a wheel that meets the following criteria:
-- 15x6
-- 4x100
-- light weight (i.e. less than the ~15# Fit Sport alloys)
-- Offset 49-55mm
-- Less than $150 per wheel (OEM alloys by any manufacturer are OK by me).
Help...?!
Old Oct 16, 2007 | 02:39 AM
MINI-Fit's Avatar
-- 15x6
-- 4x100
-- Offset 49-55mm
Help...?!
The easiest thing to do is run the stock Fit Sport rims and put R compound tires on them- either Kumho V710 or Hoosier A6
Rota wheels only go down to 15x6.5 as do many popular rims.
Tirerack.com has same limitation except for a few Sport Edition wheels
In 15x6 4x100
Sport Edition D4 Silver painted (closeout pricing)
$84 with +47mm offset 14.8 lbs
$59 with +50mm offset 14 lbs
Sport Edition E3 Bright Satin Silver Paint $84
+45 mm offset 15.6 lbs
Sport Edition E3 Machined with Anthracite accents $84
+45 mm offset 15.2 lbs
By comparison stock 15x6 rims are about 17.5 lbs each
Old Dec 25, 2007 | 12:11 AM
MINI-Fit's Avatar
Sport Edition D4 Silver painted no longer available at tirerack.com
It's possible you could find it from another source-
Sport Edition - D4 15 x 6 4x100 50mm (Silver)
Canadian $ 119.95 for each wheel= $121.59 US ! Yikes
C$ 26.00 for each wheel shipping to US
C$ 583.80 for set of four rims shipped to US
Sport Edition D4 Wheels | TireTrends : Save on Sport Edition D4 wheels!
Old Dec 28, 2007 | 04:41 PM
Popeye's Avatar
Old Dec 28, 2007 | 06:58 PM
Skimmer's Avatar
Nope. Too wide (6.5") and the offset isn't within specs. The rules require stock width of 6" and no more than about 6mm of additional offset, which means about 49mm. These wheels are 43mm.
Old Feb 20, 2008 | 12:31 AM
MINI-Fit's Avatar
I tried out the Sport Edition D4 in 15x6 with +50 offset.
Seems like it's more than 14 lbs each. More like 16 or very close to stock weight. Kumho V710 205/50-15 tire and rim was 34.4 lbs and tire is supposed to be about 18 lbs.
I ran stock rim with stock Passenger All Season tire then with 15x7 Kosei rim with 195/50-15 Bridgestone Potenza RE-01R tires. The All Season tires were about 32.2 seconds per run, RE-01Rs were 30.7 (1.5 sec difference).
Next day on another/longer course, best run with RE-01R was 35.99 and best on V710s was 35.81 for less than 0.2 difference.
This leads me to think that autocross or track with RE-01R on stock wheels is good enough using 195/50-15. R compounds will cost more and not really deliver that much more performance given the stock power and suspension.
I was running -0.8 camber in front with help of crash bolts x 2 each side and -1.6 degrees in the rear, 1/8" toe out in front which is the limit of stock settings with 1/8" toe in for the rear.
Handling was fine, power was lacking due to automatic transmission and gears that seemed too low (first) or too tall (2nd) with not enough torque down low.
Old Feb 20, 2008 | 03:48 PM
Skimmer's Avatar
Yeah, that's one option I've thought about, too: run "street" autocross tires all the time -- in daily use and on the track. It won't work in some climates, but it might be the most affordable option for some people in the long run. You do give up a little bit, as you noted, compared to an R-comp tire, and in a competitive region that could make the difference.
It's worth noting you could probably get a 205 tire on the stock rims, which would be a further advantage.
I decided to go with the Saturn 'sawtooth' 15x6 wheel and Kumho V710 R-comp tires in 205/50/15. I got the sawtooths for $100 at the junkyard, they are about 2lb. lighter than the stock Fit Sport wheels and have a 5mm better offset. I got the Kumho's barely used for $200 from another autocrosser off his Miata, and he got them mounted for me for free. So the whole setup cost me $300. Scrounge around and you can probably do the same.
Old May 29, 2008 | 03:49 PM
mahout's Avatar
[quote=Skimmer;183228]I'm planning to run my Fit Sport in my local region's H Stock autocross class. I have some experience in autocross and want to be competitive. So I plan to run R-compound tires, so I need a spare set of wheels to mount them on.
My recommendation is
1. use 1/4" spacers; they are really 6 mm so you're fine.Make sure you still have 1/2" thread length useable on the lugnuts tho. You don't need new wheels if you have to keep same wheel width as stock but are allowed 1/4" offset improvement.
2. Check Grassroots Motorsports mag for wheels; their TireRack wheel ads include wheel weights
3. Use 205/50x15 Hoosier, Falken, or Kumho comp type tires.
4. Disengage front antisway bar to reduce understeer. If you need to practice Fit rotation in corners find a vacant lot. Rotation is the key to fast times.
Thats a cheap budget.
And you should reserve R tires for the A/X's. Get an inexpensive set of aftermarket wheels/tires 15, 16, or 17's from DiscountTireDirect, TireRack, or EdgeRacing, among others, who mount, balance, and ship for free, for the street. About $500-600 will do it nicely. Count on 42 mm offset minimum and 205 section tires.
Good luck.
Old Jul 4, 2008 | 05:57 AM
eddy123's Avatar
Thanks for the information. I have noticed the engine braking that you had mentioned.
Old Feb 6, 2015 | 08:25 PM
glockprime's Avatar
Reviving this thread. I've been looking for a light 15x6 wheel for stock/street class but haven't been able to find any, except for the Sport Edition mentioned here, which isn't very light imo. The GE8 stock wheel is 16x6 53mm offset, so I can go down to 15x6 47mm offset. The offset is the catch, since just about every 15x6 wheel has less than 47mm offset. Any fresh ideas?
Old Feb 13, 2015 | 10:28 PM
Greasyman's Avatar
Some stock Miatas have 15x6 wheels, but with 45mm of offset, or so the webpage claims. I'd look into those, you can get them cheap, and they should bolt right up. Someone would have to be a dick to begrudge you 2mm, especially if you aren't beating everyone. Table of Wheel Weights
Old Feb 14, 2015 | 12:43 AM
glockprime's Avatar
I'd rather not cheat by 2mm, especially since it looks like Weds has a good legal 15x6 option.
Old Feb 16, 2015 | 11:20 PM
Rollerboots666's Avatar
-- 15x6
-- 4x100
-- Offset 49-55mm
Help...?!
You can run R compound tires in H Stock? I thought in any street class it was 200 UTQG rating as of 2015.
Old Oct 26, 2015 | 03:52 PM
glockprime's Avatar
Just noticed that the rules have been relaxed from 0.25" to 7mm. So now we can go down to 46mm offset.
Old Nov 25, 2015 | 12:35 PM
glockprime's Avatar
Old Nov 25, 2015 | 01:13 PM
dwtaylorpdx's Avatar
Circle Racing Wheels
You can get almost any config from them and they are VERY light..
And NO they are not as pretty as some wheels, they are race rims.
Old Nov 25, 2015 | 01:48 PM
glockprime's Avatar
Good info, thanks. Any idea on rough pricing? And by very light, are we talking under 10 lbs?
The Weds are fine mostly. Ideally would shave off 2mm and at least 2 lbs.
Old Nov 25, 2015 | 07:06 PM
Its been about 2 years since I bought any, as I recall they were about 100 bucks? I think I killed those brain cells. But the gal on the phone was ver knowledgeable and we ran them on a 200SX turbo (S13) in SCCA/NASA events.. And despite some 130 mph getoffs a couple times they never got warped out of true..
I never weighed them, without rubber they were a 2 finger wheel. They make a couple different styles some that are NOT of street use as they are too light duty, strictly a asphalt track wheel for light cars.
bread bucket
Sep 15, 2008 05:15 PM
HONDAJUNKIE
Jun 16, 2008 11:19 AM
tlm911
Dec 3, 2007 11:04 AM
Apex77
Sep 14, 2007 04:37 AM
FireFit
Sep 13, 2006 03:38 PM
