T1R suspension HELP-->
Old Oct 28, 2007 | 09:51 PM
FELIXY69's Avatar
hi
i got a set of T1R coilovers from a fourm member
i didn't get any instructions on how to Adj. it
my question is .where are these adjustment at?
-camber --do i need the optional pillowball top mount to use this function ?
-36 way compression --this must be the knob ontop ?
-rebound -- where is this ? usally on the bottom, but i don't see it ?
also my fronts are kinda weird, the rubber bushing on top can move when i turn the steering wheel. but the bolt is tight, and you can see it's tight cuz you can see the bushing is kinda mushed down.
this is also causing it to creak..and makes weird noise
thanks for your help
Old Aug 9, 2008 | 05:03 PM
cowflex's Avatar
I was wondering if you ever fixed the problem with your front coilover. I had mine installed a long time ago and they've been running fine until recently. Now whenever I go over anything that's not flat on the road and I hear a weird clunking noise. It makes the noise too when I press up and down on the front of the car. Never had this problem before and I tried everything. Had all the bolts re torqued, did an alignment, nothing I can think of to fix the clunking noise. It's just my front left that's making the noise, everything else is fine.
Old Aug 9, 2008 | 07:42 PM
check your endlink nut. if you're sure it's tight, undo one endlink and
drive down a predetermined road. it could be your endlink's joint itself.
Old Aug 9, 2008 | 08:52 PM
cowflex's Avatar
thanks for responding, I actually just got back from putting the fit baby back together. Turns out that the clunking noise was actually one of my last few theories.
My whole coilover was solid, nothing was loose and I know the install was correct. The last time I had taken the suspension out I saw that the factory rubber bump stop was damaged on the inside rim that sits around the nut of the coilover. I didn't think to much of it until I realized that the inside of the rubber bump stop is metal, thus the clunking noise. I ended up putting some rubber rings between the nut and the rubber bump stop and i finally have silence , hope this helps anyone that comes along with this problem. Took me a couple days and a lot of pondering to figure out where the sound was coming from.
Btw I believe the rubber bump stop was damaged when I drove over a really bad pothole I didn't see coming. It bent my rim and effed up my tire a bit too.
Old Aug 9, 2008 | 08:56 PM
cowflex's Avatar
now I just need to figure out where I can get new rubber bump stops.....
Old Aug 9, 2008 | 10:17 PM
wat? the T1R's use factory bumpstops? or are you
referring to the rubber top mount, lower half?
Old Aug 10, 2008 | 01:30 AM
cowflex's Avatar
err sorry yeah I think I am referring to the rubber top mount, lower half. I'm running on skunk pro-c's though
Old Aug 10, 2008 | 07:46 AM
yah, im sure your dealer can get those no prob.
Lightarrow
Mar 2, 2010 09:16 PM
danger69
Jan 21, 2010 12:48 AM
trancedsailor
22
Mar 4, 2009 12:46 PM
whtsjdm
Jun 16, 2008 04:59 PM
Henry
Aug 4, 2005 08:31 PM
