15" SSR Type-C & 17" Enkei RPF-1
Old Oct 29, 2007 | 02:14 PM
alim ulama's Avatar
specs:
15x7 ET35 on Advan Neova 195/50 R15
great grip, but since the circumference is smaller that the stock tire.. the ground clearence a li'l bit too low for my liking.
specs:
17x7 ET43 on Yokohama A.Drive 205/40 R17
nice looks, but for handling, not as good as the 15" setup.
Old Oct 29, 2007 | 02:59 PM
fits_all's Avatar
looks really nice on both set of wheels. The drop looks better in with the 17's..are those coilovers or springs?
Old Oct 29, 2007 | 03:03 PM
leandro82's Avatar
Originally Posted by alim ulama
specs:
Nice, I like the look with 15"s much better. 35mm offset seems low - did it rub? And did you need to mill parts or use spacers.
Old Oct 29, 2007 | 03:06 PM
alim ulama's Avatar
thx bro.. those are Tanabe NF coilovers.
Old Oct 29, 2007 | 03:10 PM
alim ulama's Avatar
rubs a li'l bit, had to grind the inner fender.
Old Jan 15, 2008 | 08:48 AM
kencengpenyok's Avatar
specs:
specs:
i like rpf1 better than buddy club sob.
is that fujitsubo muffler?
Bagus bos mobilnya
Old Jan 15, 2008 | 10:22 AM
SD_MR_FIT's Avatar
i have always love the rpf1 on a lot of different cars. from civics-s2000. i think for the fit the 16x7 version would have set the rpf1s on the fit HARD. but 17s look decent aswell. anyways nice looking wheels though
Old Jan 15, 2008 | 12:29 PM
doctordoom's Avatar
Supervillain
ooh i like it on the 15" SSRs!
Old Jan 15, 2008 | 01:28 PM
i'd go with RPF1's in 15/16's. those 17's look good on my cooper-s.
Old Jan 15, 2008 | 01:31 PM
Combo's Avatar
is the 195/50 a good setup to go with 15" ? do you feel it's a bit too thin? i have type-c wheels too justwaiting for tires to come in
any rubbing issues?
Old Jan 15, 2008 | 03:58 PM
195/50/15's are nice setup. i run them and they work great. also get
the benefit of slightly better gear ratio for acceleration.
the 195/55/15's look fine on stock wheels but they're too balloon-ish
when use on aftermarket wheels with aggressive offsets.
Old Jan 16, 2008 | 02:36 AM
Evotech8's Avatar
Do you guys notice how much your speedo is off with the shorter 195/50/15's vs stock 195/55/15's?
Any noticeable decrease in gas mileage?
Old Jan 16, 2008 | 01:58 PM
jim@tirerack's Avatar
Former Vendor
The height is off by 3/4". I would not recommend it because you get more wheel well gap. If the car is not lowered it just won't look right. You could use a 205/50R15 and get a little wider and raise the height up about 1/3" over the 195/50R15.
SBT
Jan 18, 2012 03:43 AM
fitinfit
Mar 29, 2011 10:02 PM
phenoyz
Oct 26, 2010 02:39 PM
Illusive
Greater Calgary Community
20
Jul 8, 2009 10:37 PM
SHiFT
Oct 15, 2007 02:19 AM
