Can I drive my 1992 Honda Civic DX???
Old Oct 17, 2005 | 01:30 PM
john_williams1000@hotmail.com
Guest
Posts: n/a
I have the vehicle named above. This morning after driving to work, I
noticed that the engine temperature was much higher than normal, and
there was coolant on the ground. Then I tried the heat in the car, and
only cool air would blow out from the heater. I turned off the car
immediately.
I don't know if this is the water pump, a hose, or the radiator. I
have an appointment with my mechanic in a few days.
Can I drive this vehicle at all without damaging it? May I drive it
short distances if I watch the heat guage? Thanks for the
information...
Old Oct 17, 2005 | 03:37 PM
Elle
Guest
Posts: n/a
Re: Can I drive my 1992 Honda Civic DX???
I would avoid driving it.
If you must drive it, have a gallon of at least distilled water in the back.
Check the reservoir level after every trip. Have the heater set on high, and
run the blower full speed.
If the temperature gage climbs high, stop the car.
The risk you are running is not having proper cooling of the engine, the
outcome of which can be a warped cylinder head and damage that will cost in
the thousands to repair.
<john_williams1000@hotmail.com> wrote in message
news:1129569853.980956.52870@z14g2000cwz.googlegro ups.com...
> immediately.
> information...
Old Oct 17, 2005 | 05:39 PM
Misterbeets
Guest
Posts: n/a
You're way low on coolant, as shown by lack of heat. Fill and bleed the
radiator first, warm it up fully and check for leaks, then decide.
Old Oct 17, 2005 | 07:30 PM
TeGGeR®
Guest
Posts: n/a
"Misterbeets" <misterbeets@gmail.com> wrote in
news:1129579829.920977.235300@g43g2000cwa.googlegr oups.com:
> john_williams1000@hotmail.com wrote in
> news:1129569853.980956.52870@z14g2000cwz.googlegro ups.com:
>> immediately.
And check why you're low, too. This is often a sign of a failed head
gasket. If ignored, this will trash your engine.
TeGGeR®
www.tegger.com/hondafaq/
Old Oct 17, 2005 | 08:30 PM
SoCalMike
Guest
Posts: n/a
> immediately.
could be a busted 14 year old hose.
> information...
fill it with water, start it, see where the water goes. i wouldnt drive
a car with a leak that severe.
Old Oct 19, 2005 | 02:32 AM
Burt S.
Guest
Posts: n/a
<john_williams1000@hotmail.com> wrote in message news:1129569853.980956.52870@z14g2000cwz.googlegro ups.com...
> immediately.
> information...
An improperly bleeding on certain motors can blow coolant into the
pavement caused by steam. Honda permits driving the vehicle as
long as the needle does not touch the red mark.
mat77
Jan 12, 2017 09:48 AM
frantic_2003
Jan 22, 2015 09:23 AM
~murr~
Nov 24, 2008 11:32 PM
danielle1432
Oct 10, 2005 12:36 PM
theo.chan@gmail.com
Aug 8, 2005 11:48 AM
