What to look for when buying a set of used wheels?
Old Nov 2, 2007 | 09:15 PM
Blaw's Avatar
Hello all. I am a complete noob when it comes to auto parts, so I seek advice. I am preparing to buy a set of used OEM Honda wheels from craigslist. What should I look for when I check the wheels out before buying? I kinda have an idea of how to tell if the tires have life left. Is there a way to tell if the wheels spin true or that the metal is not fatigued? Wheels are pretty expensive, so I want to avoid problems. Thanks in advance.
Old Nov 6, 2007 | 04:43 PM
CarDemon's Avatar
Senior Member
Specs...bore, offset, size, bolt pattern are the most obvious...as for the rest you actually have to go inspect in person and look closely at the rim's integrity for major or minor hairline fractures I guess.
Old Nov 13, 2007 | 03:39 AM
art086's Avatar
If possible u can try to put the wheels on wheels balancing machine and see the rotation and the "balance weight" that has to put into the wheels. If more than 100 grams (or more, i'm not so sure) then something wrong with the wheels. If less than that and the rotation movement good, u can be sure it's good
dampcurse
Apr 13, 2019 04:09 PM
Creid00
Jun 16, 2012 12:18 AM
Fit GE
Jan 8, 2010 04:10 PM
un_designer
May 2, 2008 03:37 PM
Crixtala
Aug 6, 2007 10:58 AM
