Stereo Installed - Airbag Light is on!
Old Nov 6, 2007 | 03:49 PM
gregorsCamp's Avatar
Hiya. I installed a stereo unit in my fit a few months back, and everything went well. This past weekend, I took the stereo unit out so I could run an extra wire through, and fix an issue with how the unit was sitting. After putting it all together again, my airbag light has come on. Doh!
Any ideas on what I did? I'm hoping it's just a fuse? The reason behind this, is just this last time, I realized I forgot to unhook the negative terminal from my battery (idiot, I know).
Any help would rock. Thanks so much!
Ryan
Old Nov 6, 2007 | 11:54 PM
Injundon's Avatar
Did you at any point put the key to ignition while the airbag light was unplugged?.. Otherwise you forgot to plug the light back in.. or the it's just a random occurance.
Old Nov 7, 2007 | 11:56 AM
Thanks so much for the response!
I know I had put the key in the ignition to test the radio was working, but I thought I had done it after I had plugged everything back in. If this is not the case, did I break something?
Old Nov 7, 2007 | 08:46 PM
Injundon's Avatar
Nothing broken.. just a code.. Disconnect your battery for about an hour. then re-connect it and do the idle learn procedure and the code should go away if you just put the key to ignition while it was unplugged.
Otherwise you gotta go to Honda to have the code checked and removed.
Kyaw Kyaw Cho
Aug 21, 2014 07:11 PM
mdsniper7
Feb 27, 2012 03:11 PM
greyfox
Jul 29, 2010 05:53 PM
lovelyfit
Mar 13, 2009 10:47 PM
Batman
Dec 15, 2008 03:01 PM
