Skidplate for the Fit?
Old Oct 10, 2008 | 08:53 PM
Ferretman's Avatar
Smile Skidplate for the Fit?
Does anybody know of a company that sells skidplates for the 2007 Fit?
I traverse a gravel road fairly frequently and have had the Fit into the shop a couple of times for damage done by rocks I didn't quite dodge quickly enough. It occurs to me that a skidplate might make a lot of sense, but before I go contact a metal shop about making one I thought I'd check to see if anybody knows about one that might be for sale out there somewhere.
Thanks much.....
Steve
Old Oct 10, 2008 | 09:04 PM
solbrothers's Avatar
theresthe beatrush underpanel, but i doubt that is what you are looking for
Old Oct 25, 2008 | 10:08 AM
Ferretman's Avatar
Just a quick update: I've done some searching and consulted with the local Honda mechanics, but they've not heard of such a thing nor have I found anything online.
Reckon the next stop is a custom shop to get a bid on making one.....I'll post with updates as they occur.
Ferretman
Old Oct 25, 2008 | 11:24 AM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
As Matt said, Beatrush makes an underpanel.
Old Oct 25, 2008 | 01:09 PM
Ferretman's Avatar
Question Underpanel vs. Skidplate
True, and I looked at that but there's not enough info on it on the site. It looks like it's metal but it doesn't actually say that anywhere that I can find. Does anybody know?
Steve
Old Oct 25, 2008 | 01:43 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
Steve
you can't call them or even email them?
Old Oct 25, 2008 | 01:59 PM
Ferretman's Avatar
Dang, if only I'd thought of that......
<grin>
As of my post earlier they hadn't answered, unfortunately. I've been poking around other forums to see if somebody else might have bought this but so far no luck--which is definitely a bummer.
When I pictured this thing in my head I actually had it running farther back under the driver rather than just under the engine compartment proper. If I had one custom made so that it extended farther back I'd need to ensure that I put those vents in there for cooling.
Just noticed your .sig--you're going to lower your Fit? Here I am wishing I could raise the dang thing! Guess it all depends on where you drive, huh?
Old Oct 25, 2008 | 04:11 PM
chimmike's Avatar
Drive slower.
Seriously, the Fit is a road-going car. Was never meant to super-speed along dirt/gravel roads.
Your only option, IMO, is a fab shop.
Old Oct 25, 2008 | 04:15 PM
Posts in the NUUDE
Its aluminum I believe. It takes some mods to fit as its made for the JDM Fits.
Just some metal brackets.
I drive my car like everyone else. I actually had some fun on a muddy road last night.
Since my car is so low, I DO want a gas tank guard. Just for safety.
Old Oct 25, 2008 | 09:16 PM
Ferretman's Avatar
Red face Skidplates and Whatnot
Originally Posted by chimmike
Drive slower.
Yeah, it's really intended to have asphalt under it. Unfortunately my new house is up a gravel road so, there ya go.
Funny thing is my old Tercel (1988) never had any trouble on this road with rocks or whatnot, but then it was a smidge taller than the Fit as well.
Steve
Old Oct 25, 2008 | 09:18 PM
Ferretman's Avatar
Thumbs up Skidplates and Whatnot
It is a terribly low car. I love it, but that part definitely takes getting used to....I now know the "flat" entrance/exit to every parking lot around!
I think I'll get an estimate on what it might take for a heavier duty skidplate, and then I'll figure out whether to go with this item or have it custom made.
Thanks for the materials info!
Steve
Old Oct 25, 2008 | 09:33 PM
kylerwho's Avatar
spoon fed
try get diamond plate 1/8" 6061 aluminum. i built a couple for some ford guys. im not sure on pricing because i just fabricate and weld them.
Old Oct 25, 2008 | 11:17 PM
SD_MR_FIT's Avatar
i need one that covers from the front to behind the gas tank. i soon will be really low. so i dont want anything to really screw up my liquid tanks.
Old Oct 26, 2008 | 12:20 AM
Ferretman's Avatar
Exclamation Full Undercover
I'll ask what that might cost when I have the shop here give me an estimate; that'll give you something to go on, anyway.
Steve
Old Oct 26, 2008 | 09:43 AM
chimmike's Avatar
I wouldn't cover the entire undercarriage, because Honda may have engineered the engine bay to route air through the rear bottom of the engine bay.
Old Oct 26, 2008 | 09:49 AM
niko3257's Avatar
<grin>
lol sorry about that.
one quick thing you can do to raise the car is get bigger tires.
just 1, 2 or 3 side wall numbers higher and you'll be good.
my dad does this in the winter on his corolla. he has an
extra set of wheels mind you. but in any case he does it for the
winter with taller tires. never gets stuck thanks to his
ALL-TRAC
also keep us posted if you come up with any prices on the
custom plate.
Old Oct 26, 2008 | 10:24 AM
Ferretman's Avatar
Thumbs up Raising/Lowering
ALL-TRAC
custom plate.
Hmmm...I hadn't thought about that. The tires that are on there are the stock ones (still in pretty good shape) but I'll bear that in mind down the road. Doing this would give you what, maybe a half inch? Anything would help I think.
Thanks for the tip!
Steve
Old Oct 26, 2008 | 10:26 AM
Ferretman's Avatar
Cool Covering Entire Underbody
He does raise a good point, actually....it may be engineered to use the flow of air to cool the tranny and such.
Steve
Old Oct 26, 2008 | 11:19 AM
chimmike's Avatar
I know the s2k is designed to allow air to exit the bottom rear of the engine bay, kinda creating a scavenging effect to pull air thru
Old Oct 26, 2008 | 12:50 PM
kylerwho's Avatar
spoon fed
if that is the case then i wonder if the s2k engine runs hotter with this on
Password:JDM Dry Carbon Complete Bottom Diffuser Package (S2000) | JDM Honda Parts, JDM Honda Engines / JDM Nissan Motor Swaps, Used JDM Parts - Password JDM
