DIY Transmission Fluid Change
Old 05-14-2007, 07:58 PM
lamyun's Avatar
Hey everyone, didn't really see a DIY for changing the transmission fluid so I decided to make one. Standard disclaimer, do at your own risk, etc, etc.
Very simple task, similar to changing your oil but less messy because there is no filter to remove.
Here are the tools that you need:
2 quarts Amsoil Syncromesh Transmission Fluid
Rachet set (I believe the fill plug was 18mm)
Suction pump
Drain pan
30mins time
Level ground
Step 1: Jack up the car on the driver side
Step 2: Loosen the fill plug first. Why? Because if you drained the trans and cant break the fill plug loose, you are screwed.
Step 3: Place pan under the drain hole and let it drain.
Step 4: Put the drain plug back in.
Step 5: Using the suction pump, suck up the amsoil fluid and squeeze into the fill hole.
Step 6: Repeat step 5 until fluid is dripping out of the hole. (~1.6 Quarts)
Step 7: Put the fill plug back and tighten the two bolts.
Step 8: Clean up, you are done!
Took around 30mins to complete. Impressions? Slightly smoother shifting and peace of mind when I take the car to the track this summer
Enjoy!
Old 05-15-2007, 02:00 PM
john trials's Avatar
To save a few $, you can use a funnel and tubing (from hardware store) instead of the hand pump. Put the tubing into the trans fill hole from the top side of the engine compartment; insert the funnel in the top end of the tubing; pour man trans fluid into funnel and let gravity fill the trans.
That's a great tip on removing the fill plug first!
Old 05-15-2007, 03:33 PM
milano sol's Avatar
nice write up!
good pics too
Old 05-19-2007, 01:00 AM
feifei's Avatar
NICE!!!! but how can i tell is it enuff fluid or not?
Old 05-19-2007, 01:21 AM
Deivioncrx's Avatar
Fluid should be right at or dribbling out of the Fill plug when its Full
Old 05-19-2007, 01:23 AM
quangalang's Avatar
well your car has to be level to the ground and you just fill it up til you see fluid coming out of the fill hole, the level of the fill hole is the level that you should fill it to.
Old 05-19-2007, 01:26 AM
quangalang's Avatar
i heard the GM synchromesh is really smooth also
Old 10-11-2007, 03:15 AM
martymcfly's Avatar
I think both washers should be changed also.
Old 10-20-2007, 05:12 PM
RubyQQ1211's Avatar
what's the interval on changing MTF? I heard people said that you don't have to do it on a MT....
Old 10-24-2007, 11:32 PM
report back about how the Amsoil MTF works out, ive been reading alot about it, thinking of useing it when its time to change.
Old 10-24-2007, 11:43 PM
martymcfly's Avatar
I have not done this to the Fit. However, I have been using Amsoil MTF on my accord since 2001-2002. I can definitely feel a difference in smoothless in getting into/out of gears. I have also "amsoil" my Taco 4x4 with engine oil, MTF, transfer case, and rear differential. Some hard core 4x4 wheelers folks swear by them. 2 quarts doesn't cost much and it is a pretty good investment.
Old 10-25-2007, 07:39 AM
For my 92 and 96 Civics, the shop manual says every 90K miles for normal driving or every 30K miles for severe driving conditions for a MT fluid change. I do mine every 30K...it is easy and inexpensive insurance. I've never had a MT problem.
For the Fit, wait for the computer to tell you, or do it when you feel comfortable. I'll probably still refer to the maintenance chart for my Civics when doing the maintenance on my Fit.
Old 10-31-2007, 09:19 PM
RubyQQ1211's Avatar
I had been looking at CSK, AutoZone, Walmart etc etc and I couldn't find any MT fluid for sale. Any suggestion at where to get these?
Old 10-31-2007, 10:11 PM
manxman's Avatar
Look in your phone book for the nearest Amsoil dealer, or go to AMSOIL Corporate - Source of the World's Best Synthetic Lubricants - Motor Oil and Filters and sign up for your own dealership. You can buy products at wholesale then for every lubrication and filter need for your Fit. Amsoil products are not sold in parts stores.
You are welcome to join the other Bay Area Fit owners for our Nov. 10th. Fit Meet on Mt. Hamilton in San Jose.
Old 02-11-2008, 01:04 AM
RubyQQ1211's Avatar
I did the fluid change. But when I filled it up, my driver side is still jacked up. I am pretty sure I have more than 1.6qt in it. Is it ok if I have more fluid in it?
Old 02-11-2008, 08:58 AM
claymore's Avatar
No............
Old 02-11-2008, 12:16 PM
RubyQQ1211's Avatar
No it's not ok?
Old 02-11-2008, 12:44 PM
martymcfly's Avatar
Does anyone know what the torque spec is? They don't seem to be very tight so I just hand-tight it. I suspect they are about somewhere around 30lb/ft torque range?
BTW the fill plug is 17mm.
Old 02-11-2008, 01:05 PM
manxman's Avatar
No it's not ok?
No, it's not OK. Car must be level, otherwise you will either over-or-underfill depending on which way it is slanted.
Old 02-13-2008, 04:14 PM
RubyQQ1211's Avatar
I am sure I overfilled it because I only jacked up the driver side. But the extra oil are just sitting there right? I assume it won't hurt. ><
Quick Reply: DIY Transmission Fluid Change
