The OFFICIAL Fit Shoes Thead! (Lug Nuts Included!)
Old Mar 11, 2008 | 11:01 AM
  #381
caloyski5's Avatar
Wheel: Modia/DTM KS-05
Offset: +45
Colour: silver
Tire: Nankang NS2
Lowered?: Yes
If Yes, What Setup?: Espelir Active Super Down
Front Rubbing: yes
Rear Rubbing: No
Comments: No rubbing at the rear AT LAST! nankang ns2 tires dont have rim guards. its very easy to scratch the rims since they are exposed. i installed 1/4 inch aluminum spacers upfront since the rims touch the calipers. rubs at the front during sudden dips at speed
Old Mar 13, 2008 | 01:27 PM
  #382
nc26's Avatar
Hey guy's sorry for being noob or anything, but does the setting HAVE to match with a particular set of rims or does it not matter?
Old Mar 15, 2008 | 03:29 PM
  #383
fitoromocto's Avatar
Wheel: Drag Wheels DR-23
Offset: +40
Color: Black
Tire: Nexxen N2000
Lowered?: Yes
If Yes, What Setup?:Eiback Pro
Front Rubbing: Yes
Rear Rubbing: Yes
Comments: rubbing when hitting bumps in the road and hard turn.
Old Mar 17, 2008 | 08:28 PM
  #384
StormSilverGD3's Avatar
Name: StormSilverGD3 (Even though I don't have a SS Fit anymore. I have VBP)
Wheel: Weds Racing TC005
Offset: +36
Color: White
Tire: BFGoodrich gForce Sport
Lowered?: No
If Yes, What Setup?: N/A
Front Rubbing: No
Rear Rubbing: No
Comments: Rubbing in the rear if I hit a big enough dip/bump in the road. No issues with the front. I am on stock suspension still.
Last edited by StormSilverGD3; Apr 14, 2008 at 03:40 PM. Reason: modified post text.
Old Mar 31, 2008 | 10:35 AM
  #385
ericman20's Avatar
Will it rub?
16x7
4x100
+44
205/45/16
Lowered with GF210
couldn't find anything. lol
Old Mar 31, 2008 | 10:41 AM
  #386
kelsodeez's Avatar
UNBANABLE
Wheel: volk racing ce28 time attack
Offset: +43
Color: flat black/red lip
Tire: BFGoodrich gForce kdw Sport
Lowered?: yes
If Yes, What Setup?: tein basic damper kit
Front Rubbing: No
Rear Rubbing: No
Comments: i LOVE my wheels. ever since i got them. no wheels compare to volks. lightweight and they look good. how can you go wrong?
Old Mar 31, 2008 | 10:44 AM
  #387
kelsodeez's Avatar
UNBANABLE
oh! btw, my lugs are three t1r forged lugs(black ones) and one spoon lug(red one) on each wheel.
Old Mar 31, 2008 | 11:00 AM
  #388
Illusive's Avatar
UPDATED! Thanks everyone!
What do you mean by setting? It is definitely in your best interest to select the best tires for your wheels as well as the correct offset and width. For example, 17x7 wheels which are very common can be installed on a Fit, but to guarantee you won't rub on USDM Fit's (not sure if this affects JDM ones, but I think they would), I would go with +45 offset and 195 width tires just to be sure. Some people have gotten away with little to no rubbing with smaller offsets or wider tires, but from what I've seen, that is the setup that will not rub for sure. You also want to make sure that your new rims will have the correct bolt pattern (4x100).
Originally Posted by ericman20
Will it rub?
16x7
4x100
+44
205/45/16
Lowered with GF210
That is going to be close...very close...I'd personally say it will rub a little bit, but nothing you cannot fix with sanding off some of the plastic off the rear mount. Don't hold me to this though
Old Mar 31, 2008 | 01:09 PM
  #389
nc26's Avatar
Thanks a lot illusive
Old Mar 31, 2008 | 01:57 PM
  #390
JDMchris.com's Avatar
I run THIS
Wheel: BUddy Club SF P1
Offset: +40
Color: flat black
Tire: Falken Ziex
Lowered?: Yes
If Yes, What Setup?: Megan Coilovers
Front Rubbing: No
Rear Rubbing: No
Comments: none
Wheel: Enkei Racing S
Offset: +32
Color: black with anodized red lip
Tire: Yokohama AVS ES100
Lowered?: Yes
Front Rubbing: Minor on hard cornering or big dips
Rear Rubbing: No
Comments: Too low offset, had to run my coilovers on stiffest setting to eliminate rubbing.
Wheel: Rays 57Optimise
Offset: +38
Color: Shining Silver
Lowered?: Yes
Front Rubbing: No
Rear Rubbing: No
Comments: none
Wheel: Enkei RPF1
Offset: +41
Color: Silver
Tire: Toyo RA1
Lowered?: Yes
Front Rubbing: No
Rear Rubbing: No
Comments: none
Old Mar 31, 2008 | 03:22 PM
  #391
Illusive's Avatar
Updated, thanks Chris!
Old Apr 4, 2008 | 01:29 PM
  #392
MNfit's Avatar
Wheel: Volk CE28
Offset: +42
Color: Black
Tire: Kumho Ecsta AST
Lowered: Yes
Setup: Progress Lowering Springs
Front Rubbing: No
Rear Rubbing: No
Old Apr 4, 2008 | 02:26 PM
  #393
VBPFIT's Avatar
Wheel: Konig Hurry
Offset: +40
Color: Black
Tire: Toyo Proxes 4
Lowered: Yes
Setup: GF210
Front Rubbing: No
Rear Rubbing: No
Comments: Had the car with 2 people up front and the back full in utility mode, and NO RUBBING AT ALL.
Old May 6, 2008 | 03:08 AM
  #394
methodbasic's Avatar
bumpin it up. lets see some more 17"s
Old May 16, 2008 | 03:46 AM
  #395
HONDAMATIC's Avatar
Originally Posted by F-IT!!!
whats the size of your wheel and tires? looks good with df210s
195-50-16 federal 535
wheels i have on as of now...........
drag dr16 15" 185-55-15
Old May 16, 2008 | 04:57 AM
  #396
azkikersfit's Avatar
i just wanna know if anyone here runs 5zigen FN01R in 16 inch or watever size?? i just wanna see how they look on the Fit, im thinking of getting me a set.
Old May 16, 2008 | 06:57 AM
  #397
japspeed's Avatar
do the 185 eliminate the rubbing in the rear.
Old May 17, 2008 | 06:56 PM
  #398
HONDAMATIC's Avatar
no rear rubbing at all.. i also have 195-45-16 on track Rs, but theyre bfgs, they dont rub either.. i gotta go home and see what series though
Old May 17, 2008 | 06:59 PM
  #399
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Why such tiny tires? You shouldnt rub with those springs anyway.
Old May 17, 2008 | 07:54 PM
  #400
SD_MR_FIT's Avatar
185? yeah i agree that super skinny. unless your have some crazy low offset there is no point in going anthing under 195. i personally will not go under 205.
