Individual Throttle Bodies
Old Mar 13, 2008 | 10:07 AM
Red_Rocket's Avatar
Just wondering if anyone has heard of anyone trying to develop this. It would be really awesome if it was.
Old Mar 13, 2008 | 11:28 AM
airborne200208's Avatar
Make your own! Not really all that hard, just alot of research.
Old Mar 13, 2008 | 05:02 PM
Red_Rocket's Avatar
I honestly don't think I could...I would have to find someone who'd be able to do that. Definitely do not have the skills to pull that off lol.
Old Mar 13, 2008 | 06:46 PM
kmdebit's Avatar
Check March's issue of Import Tuner, I think. There was a Toyota Starlet that had individual throttle bodies. I glanced at it the other day at the store, looked cool.
Old Mar 13, 2008 | 06:56 PM
quangalang's Avatar
it's really not that hard to do, i can probably build one, but the hard part is tuning, there is no piggy back out there that can tune for the ITBs that well. tuning itb's is one of the harder things to tune for and not a lot of people have the patience to tune it.
Old Mar 13, 2008 | 07:29 PM
tuning is definitely close to rocket science. plus you have to be able to understand pulse theory so you can get the right size trumpets or intake bells. you also need to be able to decide whether to go with a single set or a double set of injectors. lots and lots and lots and lots of time tuning. even with prebuilt sets
Old Mar 13, 2008 | 09:57 PM
George02's Avatar
yup tons!!!!!!!!!! of tunning on itb's
Old Mar 13, 2008 | 10:25 PM
underdog's Avatar
designing and fabing up an itb setup would not be hard at all. the problem lies with the lack of aftermarket support of camshafts. for an itb setup to function well you need some nasty bump sticks and lots of compression. other wise you could loose power. it is known that high rpm hp typically is lower with itb's due to the lack of helmholtz resonance to help "supercharge" the air fuel mixture. the main gain of itb's is typically nice fat tq and instant throttle response.
Old Mar 13, 2008 | 10:45 PM
dank24's Avatar
you need some headwork to get the full effect
Old Mar 19, 2008 | 11:27 PM
Masterdebater's Avatar
use gsxr 1000 itbs!! they fit damn near anything lol!!. no seriously tho. alot of custom kits consist of the itbs off of a gsxr1000.
Old Mar 20, 2008 | 01:00 AM
doctordoom's Avatar
Supervillain
yup that's very true.
Old Mar 20, 2008 | 05:33 PM
F'it_ImFromTx's Avatar
That is very true about the gsxr itb's. Allot of motorcycle itb's can fit. I don’t remember the thread specifically but there was a fellow on Honda-tech who made some for his accord out of the itb's from on older model Honda motorcycle. The fabrication should not be a problem if you have access and knowledge of how to use a machine shop. Or if you have bukoo bucks . I agree that the tuning would be the difficult part. Does any one on here have any idea of what some itb's, good head work, and proper tuning would do for our little fitties? Im really curious about what putting that much time and money would result in besides lots of head aches and obscenities.
Old Mar 20, 2008 | 05:43 PM
GAFIT's Avatar
This would require a complete stand alone ecu like a Motec due to our factory DBW and MAF. You're talking big money.
Old Mar 21, 2008 | 12:24 AM
underdog's Avatar
1000rr and 954rr itb's have all the factory sensors. the older one's works too. 929rr?? has smaller plates though. i think the 954rr itbs can support 39hp per cylinder +/-10hp asperated. higher compression with big cam's will allow bigger numbers.
Old Mar 29, 2008 | 12:16 AM
jx1c3's Avatar
since theres a thread about ITB's well im a little new about them. I was thinking bout doing ITB on my K20, but do you guys think it'll make any difference on how the car is driven; ie comfort? because my Fit is a daily driven car.
Old Mar 29, 2008 | 01:07 AM
HondaFitted2007's Avatar
my friend that was looking at my engine said that because how the engine is situated, ITB's would make it hella loud since the intake manifold is closest to the cabin and also, running ITB's could be hazardous in rainy places (like oregon)
Old Mar 29, 2008 | 03:29 AM
claymore's Avatar
Your friend needs to take a closer look. The intake ports on a FIT are on the Front of the engine the farthest away from the cabin part of the engine. The ITBs would be mounted there way in the front of the engine bay. And unless you are in the habit of driving through puddles over your wheels water would not be a major worry.
Old Mar 29, 2008 | 12:05 PM
some peoples kids/\
Old Apr 12, 2008 | 11:25 PM
wontfit's Avatar
Thumbs down actually....
i've lived here in portland for awhile now. it doesnt just rain like other places. IT POURS. and it pours forever! never ending rain. ITB's wouldn't be bad here. but the risk is too much. especially on 82nd ave. in se portland . it has the WORST potholes, and they fill with water.
Old Apr 13, 2008 | 04:24 PM
mahout's Avatar
Good grief, Red Rocket. Your idea isn't that hard but has little advantage. All you need to do is duplicate the fuel control computer systems using air intake and rpm to produce 4 fuel maps for a Fit ! Very costly yes but also not likely to yield better fuel consumption or significantly more power.
Personally, I'd spend the effort and cost to install a Hayabusa engine in my Fit. Those cats that put one in a Smart ended up with the most entertaining videos I've seen in a long time. Somehow a 13 second (est) Fit just gives me the giggles.
