Honda Fit battery upgrade
Old Apr 3, 2006 | 03:14 AM
tonyrace_41's Avatar
Arrow Honda Fit battery upgrade
Hi co-Fit/Jazz owners! Just wanna ask regarding battery upgrade for my Honda Fit. The size of the current battery is 8x5 (l x w). Is there any Optima/Lightning Audio/Napa battery that would fit on my battery bay? I saw a Fit on HypeRev mag, having an Optima battery on his Fit, but the fuse box is on the left side of the engine bay, while mine is on the right side near the battery bay..
Please help me on this problem... I'll change my battery because of my audio system.... Thanks and more power to y'all!
Old Apr 3, 2006 | 03:43 AM
Unit 91's Avatar
An Optima dealer can help you find the right one. You just need to know the group.
Old Apr 3, 2006 | 06:23 AM
vividjazz's Avatar
Someone that Posts too much
Optima Yellow Top fits.
Old Apr 3, 2006 | 06:50 AM
Unit 91's Avatar
Which group is the battery? Looks smaller than the stocker judging by the battery tray that is now showing.
Old Apr 3, 2006 | 10:49 AM
HashiriyaS14's Avatar
One of those tiny Buddy Club batteries would almost certainly be fine.
Anyone ever used one of those? Are they okay for daily use?
Old Apr 3, 2006 | 10:54 AM
Tony@NewTypeGarage.com's Avatar
Fine for daily use but not good for upgraded audio use.
Old Apr 3, 2006 | 10:59 AM
JDMGD3's Avatar
I have a Odyssey battery which is identical to the Buddy Club and others of the same size. It works fine for daily use as long as you drive your car on a pretty regular basis. It doesnt have alot of reserve amps like its bigger normal sized counterparts also the colder the climate you live in the quicker it will lose charge. I have a small charger that I use on it if I know im not gonna be driving for a few days or your actually better off disconnecting the battery. The battery itself is only 14lbs so its a good way to reduce some weight also.
Old Apr 3, 2006 | 02:48 PM
Cool, thanks for the good info.
Old Apr 3, 2006 | 05:46 PM
dougiepants's Avatar
Avid FitFreak Poster
Optima is a great product line... I would have to say you will not complain with that...
Old Apr 24, 2006 | 04:24 PM
Pirelli P Zero's Avatar
That's too bad about the reserve issue. I want an Odyssey for the weight savings, but I'm not sure I'd be using the car daily.
Do you know how much the stock battery weighs?
Old Apr 24, 2006 | 04:38 PM
atlas's Avatar
does anybody know if any Braile batteries fit?
Old Apr 24, 2006 | 04:53 PM
JDMGD3's Avatar
Fitment as far as batteries go arent an issue as long as there equal to or smaller then stock which the Braile is. The Fit's stock battery is substantially smaller then your typical stock battery due to the the motor being so small. I highly doubt it weighs anymore then 25lbs and the Odyssey I have which is the same identical to the Buddy Club also the IDI Racing Battery and all those weigh around 15 to 16lbs. At the most you will be saving about 10lbs in weight if you do the upgrade.
Old Apr 24, 2006 | 11:14 PM
coloradocraig's Avatar
Battery rating
Can someone tell me the amp-hour rating of the stock FIT battery? What is the rating of the yellow-top Optima that fits the FIT?
Thanks
... Craig
Old Apr 25, 2006 | 03:13 AM
Bounty Hunter's Avatar
BUMP, I'm also wondering
Old Apr 26, 2006 | 09:42 PM
Woah!
VividJazz, can you send me the specs of the battery? Because I'm goin' to get one, but I'm not sure if that battery is already available here in the Philippines. The size of my car battery is 8x5x8inches (LxWxH).Thanks!
Old Apr 30, 2006 | 09:42 PM
vividjazz's Avatar
Optima Yellowtop D51R Part#8073-167. Cranking Amps 625. Cold Cranking Amps 540. Capacity 41. Reserve Capacity 70.
http://www.optimabatteries.com/publi...51R_082004.pdf
DUAL PURPOSE (STARTING & DEEP CYCLE) BATTERIES
MODEL NUMBER D34/78 D75/25 D34 D35 D51 & D51R
PERFORMANCE
Voltage 12v 12V 12v 12v 12v
Cold Cranking Amps @ 0F 750 650 750 650 500
Cranking Amps @ 32F 870 810 870 810 625
Reserve Capacity 120 98 120 98 70
Capacity (C/20 Rate) 55 48 55 48 41
Internal Resistance (ohms) .0028 .0030 .0028 .0030 .0046
PHYSICAL SPECS
Length 10" 9 5/16" 10" 9 5/16" 9 5/16"
Width 6 7/8" 6 13/16" 6 7/8" 6 13/16" 5 1/16"
Height 7 13/16" 7 5/8" 7 13/16" 7 5/8" 8 15/16"
Mimimum Weight (lbs) 43.5 37.8 42.9 36.4 26
Type Post/Terminal Dual SAE & GM Dual SAE & GM SAE Post SAE Post SAE Post
BCI Group 34/78 75/25 34 35 51 & 51R
Old May 1, 2006 | 09:33 PM
Got it sir!;-) Thank you very much for your help.
Old May 3, 2006 | 11:53 PM
badahab's Avatar
stinger makes a battery just for honda/acura's. part number spv35. 7-3/4" H x 8-1/4" W x 5" D. Should fit
http://www.stingerelectronics.com/we...ries_power.asp
you can get it here for $99
http://www.darvex.com/miva/merchant....ry_Code=BATTPS
Old May 6, 2006 | 12:05 AM
Oh, I didn't know that... If I cant get any optima d51r, I'll get the stinger spv35. Thanks a lot!
Old May 18, 2006 | 12:29 PM
macks75's Avatar
so tony what did u get?
