Okay so lowering my car, I fine out I broke both axles.
By lifting one side, than the other, it broke both axles. They aren't cheap. 600 for left 550 for right. The speed sensor was also pulled 250.00. Honda said there are no rebuilds because car is so new. Anyone on the board have used 09-14 axles?
He use a jack on each side. He jacked the left side so high, it broke both the axle on the other side. Then lifting the right side so high that it broke that axle. I did my 98 Prelude SH this way 10yrs ago. I obviously didn't do it since I'm a paraplegic now. But could they not be broken? He drove 40miles at 75mph to drop it off and I've driven it the Last two days. I don't know. If they do this to a 10 new car buyer from this dealer, ill leave them fast.
I'd guess OP pulled the inboard joint apart, pulled the tripod and rollers out of the cup, all within the rubber boot.
Hopefully the rubber boots aren't damaged.
I'd take the axles all the way out, take the metal bands off of the inboard boots, slide the boot back enough to figure out how to reassemble the tripod roller set into the cup.
Buy new bands for the boots if need be, fresh CV grease, and reassemble the boots.
Stuff the axles back into the car and drive.
I'd expect the aftermarket stores have new or reman axles cheap, if you'd rather go that route. Call around.
Local parts stores like Autozone, Oreillys, Pep boys, etc. Check their websites, look up parts for your car.
Or take apart your broken axles and reassemble the inner CV joints. Only a little more work than replacing, but much cheaper.
Wait...the title of this thread says YOU broke the axles.
Did someone else cause this damage, and aren't they responsible for fixing this damage?
Again I'm a paraplegic so I won't be doing?
rockauto has the outermost cv axles on the cheap. if u messed up the inner ur SOL, dealer only item.
maybe your guy just popped the axles out and cudnt get them back in.
and how did he drive the car with two broken axles?
Listen. I was scammed. How could my car need axles. No clicking, no pulling is i let go and lastly they tried to say lowering the car did it. I'm no FOOOOL Honda. I sat for an hour after they said dont drive it because i'd be in an accident and left. I told them the knocking they'd feel was from them Cusco 2-point bar which when i bought from a fellow member on here. Im mad as a pot of Hot grits (southerners know what grits are) right now. Im calling the service manager who ive know 12yrs there. I'm gonna call him tomorrow to see what should i hear if DRIVE-SHAFTS are broken. I'm asking you all first if my axles were bad, what should i hear/feel?
let me get this clear the dealer installed the springs for you? i know dealers wont install aftermarket.
the dealer will always say its your fault for adding aftermarket. what symptoms do you have to warrant you to bring them to the dealer?
i am so confused.
i am so confused.
no. i mention a buddy did...... they claimed i needed axles.. there is no clicking or steering problems or wandering. were going back up there tomorrow to see what they claim. a guy with a 6.67 old muscle (my installer grandfather) car looked at it too... would a car needing axles be derivable? sounds? ive lowered many cars myself. i drove it home. 1hr after service closed...lol.
when i had issues with my axle I had a bad intermittent vibration. it wasn't speed dependent. it happened randomly and most often when i was coasting. it felt like the right front passenger wheel wanted to fly off like it had a flat or something. I went to the dealer to have it looked at. they blamed the spring/shock install. said the right axle was leaking fluid. they replaced it still same problem. turns out it was the driver's side. there was clicking at the inner joint where the drivers side axle joint meets the intermediate shaft. could only be heard when we spun the tires. got a replacement aftermarket part from rockauto and installed at pepboys for a fraction of what honda ripped me off for.
sounds like there is no problem with your axles. even if ur mechanic jacked it up all the way, it would have caused your axles to pop out and he somehow popped them back in. you mention no symptoms of axle problems. if you went to get the abs sensor replaced, thats probably all u need.
So...car is driveable then?
You can have axle problems and still be driveable, but it's hard to picture BROKEN and yet still driveable.
CV joint boots not ripped open and losing grease?
Someone should get under the car to see what really happened.
goto a shop that will do a free quote/inspection. I went to Pep Boys and they were the ones who found out the faulty side and didnt rape me on the labor. I wouldn't go back to the dealer and waste hours of your time for something that they would charge you mucho dinero for.
+1
Ill YouTube for it too.
Thank you guys for the help... Keep this space
After you do you first mod, just pretend the dealers don't exist, they will try and blame everything on your mods. I had a Toyota dealer try and blame the failed alternator on my 2" lift kit on a mid 80's 4x4. (Leaf springs)
I find the stress of the dealer shyster is just not worth it even for warranty repairs unless its way expensive.
So i have update. Went to advanced and anther place to do checks on axles. no one click. The other issue, i hit a bump and the drivers side shock tower cracked the windshield. Any ideas why after spring install I had so much more of shock rod? Am i explaining this correctly?
Who installed the suspension again?
