How to disconnect the negative terminal?
Old Nov 24, 2008 | 10:59 AM
laserdog's Avatar
I have a base Fit 09.
When working on the radio it recommends disconnecting the negative terminal.
When I popped the hood it wasn't clear to me exactly how to do that?
I checked the manual and it doesn't give any advice?
Can I just tug the negative terminal up and off? Or do I have to loosen some of the hex nuts?
I know, I know, totally lame question, I'm just afraid to hurt my new car. =)
Old Nov 24, 2008 | 11:15 AM
FiveFreshFish's Avatar
Yep, you'll need to loosen the nut first before the terminal can come off the battery post.
Old Nov 24, 2008 | 11:28 AM
BakedCookies's Avatar
I'm not sure you should continue any further. Put down the wrench and step away from the Fit, LOL
Old Nov 24, 2008 | 11:29 AM
laserdog's Avatar
There is totally some truth to that.
But you gotta start somewhere. =)
Thanks for the help!
Old Nov 24, 2008 | 11:40 AM
dirtybird222's Avatar
10mm is what honda uses on all batteries. Just use a small socket or a 10mm wrench if you have too. I use a cordless drill and 10mm at work just to bust them in and out.
Old Nov 24, 2008 | 12:37 PM
pbanders's Avatar
As an aside, the Fit has the most pathetic battery ground wire I've ever seen on a vehicle. I've seen bigger ground wires in boom boxes! Hard to believe it can handle cold starting currents without being a significant voltage drop.
Old Nov 24, 2008 | 04:24 PM
mahout's Avatar
A long time ago one of the major car companies EE Manager said to turn off all accessories first, then disconnect the ground side battery terminal connector (-)by loosening the tightening nut while holding the loop on the terminal, and then removing the loop quickly to minimize the arc effect (sudden surge of electricity due to a short gap). Then you may remove the positive connection (+) the same way for thorough powering down. Remember if the positive side is not diconnected you must be certain the negative terminal loop does not come in contact with any part of the positive battery lead.
MAKE SURE THE REMOVED CONNECTORS CANNOT COME IN CONTACT WITH THE BATTERY TERMINALS OR EACH OTHER. Wrap in sturdy plastic bag is good practice.(I believe thats why the postive terminal is also disconnected; MAKE SURE IT CANNOT TOUCH ANOTHER METAL SURFACE as they will all be grounds to that terminal !)
Replace in reverse order, power side positive first, and ground negative second, again quickly putting thr loop on the terminal. And yes you will have to re-program your radio stations AND YOU WILL NEED THE RADIO CODE FOR YOUR CAR to restart & re-program your radio
Old Nov 25, 2008 | 05:28 PM
laserdog's Avatar
Awesome, thanks for the great reply mahout, that sounds like a great technique!
geepondy
Jan 5, 2019 01:59 PM
fit newb
May 31, 2015 11:04 PM
MTLian
May 23, 2015 01:14 AM
wenbellz
Nov 2, 2012 02:01 PM
Mainer82
May 1, 2009 01:12 PM
