MT Fit - Rev Limiting
Old Nov 29, 2008 | 05:14 PM
ruknight4ever's Avatar
Hey guys... I have a 2009 Fit with manual transmission. I was driving today and was merging with traffic. I was going about 65 MPH in 3rd gear. I went to shift into 4th gear and somehow I moved the box into 2nd gear. The engine revved up very loud and then I quickly shifted it into neutral.. then into 4th gear. I know manual transmission cars have rev limiters... do they work as well if you accidently try to shift the car into a gear that is too low for your current speed? Could I have hurt something in my Fit?
Old Nov 29, 2008 | 05:33 PM
kifu's Avatar
No, if you mechanically over rev the engine to over rev it and the rev limiter will not stop it.
I doubt you hurt the motor because it was only for a very short amount of time.
Old Nov 29, 2008 | 05:35 PM
halfmoonclip's Avatar
Rev limiters only work when the engine itself is supplying the revs, not when the revs are supplied to the engine by a bad downshift.
I bump into the rev limiter in my Jeep from time to time, tho' at a lot fewer turns than the Honda....
Anyway, only way to see if you hurt anything is to wait and see. The good news is that you're still in warranty. The bad news is that the computer may remember your little excursion past the redline...
Sound okay now? If so, you're probably okay.
Moon
phuccer
Jan 30, 2011 07:19 PM
wilcoholic
Jul 30, 2010 09:27 PM
wilcoholic
Apr 25, 2010 11:29 PM
ruknight4ever
Nov 10, 2008 12:56 PM
martymcfly
Oct 10, 2007 04:59 PM
