What does this light mean in the console?
Old Mar 23, 2009 | 09:04 AM
mikejet's Avatar
SO this morning after I warmed up my car and started driving a light came on that is a weird U shape with lines throught the bottom. Kind of like
There's an exclamation mark in it. I don't keep the manual in the car and can't find what it is online.
Anyone know?
Old Mar 23, 2009 | 09:13 AM
AP_ONE's Avatar
Umm, e-bake was on, not sure bud, just call honda and they will tell you forsure.
Ken
Old Mar 23, 2009 | 09:26 AM
idriv442's Avatar
It sounds like tire pressure indicator. I'll check and edit in here later.
Old Mar 23, 2009 | 09:30 AM
mikejet's Avatar
Cool thanks for checking. I thought it might be that but when the lights are all on there is a light that specifically sames TPMS so I didn't think it would be that.
Old Mar 23, 2009 | 09:39 AM
EK3 Ferio's Avatar
What color was the light?
Kinda like a handbrake light.
LOL at the ascii presentation its like an F U.
Old Mar 23, 2009 | 09:57 AM
mikejet's Avatar
Well, it was dark this morning so I know I disengaged the parking brake because of the DRL's triggering.
The light is Yellow.
Old Mar 23, 2009 | 10:01 AM
BakedCookies's Avatar
It was the Low Tire Pressure light for the TPMS, its an image of a bulging tire with an exclamation mark in it.
TPMS is the spawn of Satan himself.
Old Mar 23, 2009 | 10:04 AM
mikejet's Avatar
Yeah it is because it doesn't tell you which tire it is!
Old Mar 23, 2009 | 10:05 AM
AP_ONE's Avatar
wE DONT GET THAT IN cANADA
damn, keyboard ownz me!
Old Mar 23, 2009 | 10:06 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
just pump up your tires and you should be all set
Old Mar 23, 2009 | 10:07 AM
Type 100's Avatar
I see. The "weird U-shape" is actually an illustration of the tire carcass itself, in cross-section.
We don't get the TPMS here so admittedly this is the first time I've seen this warning light.
Why is TPMS the "spawn of Satan" by the way?
Old Mar 23, 2009 | 11:58 AM
this is the someones got a hairy butt alarm...
Old Mar 23, 2009 | 12:11 PM
FireFox91's Avatar
Sensors are installed in the wheels to check the pressure. If you want to swap your wheels out for aftermarket, the sensors go away and the system reports an error and gives you the ugly dash light. You can buy sensors for the new wheels but they are expensive.
So, bad if you want aftermarket wheels. But it is good if you just stick with stock wheels because it tells you that your tire is low when it looks like it might not be low.
Old Mar 23, 2009 | 01:20 PM
raigomaru's Avatar
TPMS
I see that you live in so cal. Mine went on this morning too, probably because it was unusually cold. It usually goes away once weather warms up a bit again.
Make sure to check your pressure anyway (33 psi) for all tires.
Old Mar 23, 2009 | 03:04 PM
that's right, its a cross section of the tire, I hate it for three reasons:
  1. I run aftermarket wheels and didn't want to drop $300 for sensors for them.
  2. It is super sensitive, if the temp goes below 40 degrees it stays on for days and the pressure will only be down a pound or two.
  3. It was federally mandated because of the Firestone/Explorer debacle. A wonderful blanket punishment for one companies piss poor quality control and the other's design failures.
Old Mar 23, 2009 | 03:43 PM
mikejet's Avatar
Got some air in during lunch and it's off now. Tires were down to 25-30. Light went off after getting them back a little above 40.
Old Mar 23, 2009 | 04:16 PM
Virtual's Avatar
It's time to check ALL 4 tires. Laziness like that is why USA Fits have TPMS.
Old Mar 23, 2009 | 09:36 PM
Type 100's Avatar
I see, thanks. I didn't know it was federally mandated due to the whole "Explorer exploding tires" issue way back when (1996?). Doesn't even seem like it addresses the issue sufficiently, too.
Call me old-fashioned, but I still believe in checking tire pressures with a good ol' tire pressure gauge every week, or every two weeks at the longest.
@ Kenchan's "hairy butt alarm" joke.
Old Mar 23, 2009 | 10:49 PM
ken_vs_ryu's Avatar
droopy butt or tpms activated.
Old Mar 24, 2009 | 12:56 AM
lilaznphatboy's Avatar
40 is a bit much you might wanna drop to as close to 33 as possible but not to go under or over by 2 psi (31-35 psi)
Evesowner
Mar 30, 2015 06:03 PM
hogwylde
Dec 9, 2010 10:31 PM
Neros
Nov 24, 2010 03:51 PM
TheRealBenzo
Sep 26, 2009 06:12 PM
Pacedog
Aug 8, 2008 01:14 AM
