Headlight & turn signal replacement for dummies
Old Jul 13, 2009 | 03:47 AM
559fitman's Avatar
So far these bulbs are working great! still only 17 bucks on amazon and I do not see any problems with them over heating cuz of the 100 watts.... Also do not see any dimming either
Old Sep 20, 2009 | 04:04 AM
frshsqzedoj's Avatar
You got a picture of the blinkers on at night? Thanks.
Old Sep 20, 2009 | 04:06 AM
Oh, nvm read the info on the lights. "Iridescent when off, Amber when on"
Old Dec 27, 2009 | 04:52 PM
Cowboy_Fit's Avatar
Just a quick heads-up to anyone replacing the headlight bulbs, the passenger side is a P.I.T.A. because of the windshield washer fluid container. I had a small issue with it, but maybe my hands just aren't meant for changing headlight bulbs :-/
Old Oct 1, 2010 | 09:59 PM
bugcpa's Avatar
I need help replacing my rear right turn signal bulb ASAP. I can't figure out how to pop off the plastic cover. So far I have scratched the paint using a flat head screwdriver! Help! I just need a picture of the notch where I am supposed to insert the screwdriver. I can't find it.
Old Oct 2, 2010 | 02:36 AM
SteveInNC's Avatar
As I recall from when I was doing a radio installation a year or so ago, you pull a plastic panel off of the inside of the car in the trunk area to get to them. Don't go from the outside. I'm indoors, and it's late, dark, and cold outside, so I'm not going to go check specifically
Old Oct 2, 2010 | 05:42 AM
Black3sr's Avatar
Pull the panel off on the INSIDE of trunk. Easy access to bulbs then.
Old Oct 2, 2010 | 12:21 PM
bugcpa's Avatar
Hmm, I'm still not getting it. Am I also prying off the gray part inside the trunk or just the clear shield? Maybe I am just afraid i am going to crack it, but it is not coming off at all.
Old Oct 2, 2010 | 01:48 PM
Black3sr's Avatar
I said INSIDE Do Not Touch the glass
Here is one of the panels you take off. This is one I have the light in.
Old Oct 3, 2010 | 07:34 PM
bugcpa's Avatar
Ooooh, that gray panel. Thank you! I was making this way too difficult. The picture help enormously and I changed my light bulb. Thank you!
Old Oct 4, 2010 | 05:46 AM
Black3sr's Avatar
You are welcome. You are halfway to now putting on some JDM tails.
Some pics of replacing mine
https://www.fitfreak.net/forums/2nd-...ght-oem-6.html
SHG_Mike
Jul 25, 2012 11:47 PM
ohanahuichubbz
May 12, 2012 07:39 PM
Stephen@CARPART4U
44
Sep 30, 2010 05:11 AM
AtticusFit
17
Jul 10, 2010 11:47 PM
mimpi
Sep 19, 2008 01:28 PM
