Tire Rotation Schedule
Old May 9, 2009 | 04:43 PM
triton.'s Avatar
Hey Guys,
Does the fit tell you when to rotate your tires? I've never had a car that required tire rotation before till now.
Old May 9, 2009 | 05:01 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
i do them at 5k or 10k.
all depends how my tires looks.
typically it's every 10k
weeladdie's Avatar
Originally Posted by triton.
Hey Guys,
I usually do it (or git-r-dun) every other oil change.
Old May 9, 2009 | 05:30 PM
SheepNutz's Avatar
I'm probably going to rotate mine every oil change. So if you never rotated your tires on your old car, were the tires directional and the wheel sizes different from front to back?
Old May 9, 2009 | 06:21 PM
Virtual's Avatar
I have a set of winter tires and when I change from one set to another, I rotate them. It works out to every ~5000 kms.
Old May 9, 2009 | 06:24 PM
05trdxa's Avatar
I usually rotate mine every other oil change. I have summer and winter tires so they each get rotated once a year, however I usually don't rotate the winter tires cause it's too cold and I wanna get back inside after changing my oil. lol
Old May 9, 2009 | 07:12 PM
schmidty86's Avatar
I plan on doing mine every oil change
Old May 9, 2009 | 07:28 PM
triton.'s Avatar
what size socket do i need for the fit? You guys recommend rotating the pattern described in manual?
Old May 9, 2009 | 09:00 PM
Virtual's Avatar
The socket size is 19mm and the tightening torque is 80 ft/lbs.
Tire Tech Information - Tire Rotation Instructions
Old May 9, 2009 | 09:07 PM
bigmitch's Avatar
I get my tires rotated and balanced every 5k miles. I pay $50 for lifetime rotation and balance at Tires Plus (Hibdon Tires) so figure I'll get my money's worth. Plus it helps to extend the life of the tires so that they all are worn out around the same time.
Old May 10, 2009 | 02:13 AM
luv4jdm's Avatar
I go by the tire manufacture rotating schedule. Which is I think for Dunlops is every 6K miles. Also forgot to mention ask whomever rotated ur tire to put the date and all that stuff on the little pamphlet.
Old May 10, 2009 | 05:49 PM
i rotate every 7k miles or so... but werdly my tires are wearing pretty evenly
front and back side to side.
i recently swapped wheels after driving about 7k miles on the 912's.
after the swap i couldn't tell which tires were where front and back.
they were all within the same wear when gauged using lincoln's head.
veazer
Nov 14, 2015 05:37 PM
moolman
Dec 21, 2011 02:19 AM
Goobers
21
Nov 13, 2011 07:04 PM
LLLC1393
Jun 8, 2011 11:25 AM
