Fit Sport fog light cracking
Old Jul 19, 2009 | 06:26 AM
I<3_myfit's Avatar
A rock flew up and put a hole in my fog light and I just notice it today. I konw for an RSX they have pre cut lexan pieces that will replace the preexisting lens cover. I was seeing if any fellow GE owners know where I can go to buy the lens cover to fix the bullet size hole in my fog light.
Thank you
Old Jul 19, 2009 | 07:21 AM
jac-Fit's Avatar
I haven't read any post about just replacing the lens cover. I think they just replace the whole unit.
Anyways, you may wanna slap on some light protection film once you got it repaired (or even use it to cover the hole?) I bought a pre-cut kit from headlightarmor.com. I should've just used bulk film to save some $$$. So far, so good.
Old Jul 19, 2009 | 03:53 PM
secondspassed's Avatar
^What he said. I slapped some film over my shattered fog light and now I don't have to worry about water getting inside, etc.... and it will probably last forever! Save yourself $100 and don't replace the housing.
Old Jul 19, 2009 | 04:57 PM
SheepNutz's Avatar
You can't replace just the glass. If you want to replace it, you need to buy the whole housing. I already had one shatter, and I replaced the housing then put protective film from Headlight Armor on the glass. It's held up so far.
Old Jul 19, 2009 | 05:18 PM
Committobefit08's Avatar
I put protective film on mine. I bought 6" film sheets. I cut a stencil and cut it to match shape of the lens. I took a 1000 mile road trip a couple months back...so far so good.
Old Jul 19, 2009 | 08:22 PM
jadr09fit's Avatar
We put yellow films on the fogs. It'll be a nice contrast when the snow starts flying.
Also, J said that a stick was lodged in between the lens and the plastic surround. Glad we put the films on right away!
Old Jul 21, 2009 | 02:21 PM
vwli's Avatar
I used glass sealant to seal the hole. And this is how I protect my fog lens after the crack.
Old Jul 24, 2009 | 02:40 AM
559fitman's Avatar
Read my DIY
Old Jul 25, 2009 | 02:51 AM
Kouki's Avatar
So did I, Im such a ricer.
Old Jul 25, 2009 | 02:56 AM
I<3_myfit's Avatar
Went to Lowe and picked up lexan glass. pulled my fogs and got a dremel and cut out new lens. Got some silicon to glue the lens to the fog light. First fog light i kind of messed up on. Second one not to to bad. I will post pictures up.
Only problem is the glass isnt curved like how the stock lens cover is.
Old Jul 25, 2009 | 11:31 AM
Whats A Fit?'s Avatar
I did as well...
56chevydan
Sep 3, 2019 06:32 PM
Aznsupastar
Sep 6, 2018 10:12 PM
robs
Mar 11, 2017 02:16 PM
cwinfrey
Mar 8, 2014 08:44 PM
ev0le
Sep 7, 2009 02:58 PM
