My new Build
Old Aug 6, 2011 | 12:45 PM
britdevine's Avatar
My new Build
So I redid my box today..havent really posted much on here about my system.
Here are a few pics
DLS A7 5 channel in the tire well with an Extra Kinetec HC600 Battery...I curently am running a pair of Shok Industries 6.5 components in the front seeing 200w per side...Have a set of Massive RK6 components on the way
XS Power D975 under the hood
New Sub box I built and painted...Sub is an AudioQue HDC3 10 Dual 2 ohm...I spent ALOT of time building this...so much sanding...sanded between all 3 coats of primer...and all 3 coats of paint. I need to carpet the floorboard and I will be all set now! Box can be taken out in about 1 minute, so It's easily removable if I need the hatch area.
Box is 1.45 cuft net..tuned to 36.5 with a 4 inch aeroport..it is the best sounding sub/box combo I have had for daily ever....and I have had alot
Here is an old/bad pic of my car..since it's been tinted and Smoked tails
Old Aug 6, 2011 | 03:36 PM
jayhawker's Avatar
Do you have the cargo cover? I'd be worried about someone walking by and attempt to do a smash and grab seeing how that box stands out so much. Do you plan on doing any type of deadening to the doors?
Old Aug 6, 2011 | 05:59 PM
britdevine's Avatar
Yea I have the cargo cover...1st thing I bought after I had the car.
I will be deading the doors with some Second Skin Damp pro when my new comps get in...and I will also have to do something to the hatch....wow does it rattle now
Old Aug 8, 2011 | 02:29 PM
beangrower's Avatar
Originally Posted by britdevine
S
just curious as to where those extra power and ground wires are running to?
is it directly to your alternator and block?
Old Aug 8, 2011 | 03:01 PM
britdevine's Avatar
The 4 gauge are going to the battery I have in the tire well of the car, 1 wire for + 1 for -, to connect the batteries together to allow more power to the amplifier which is hooked to about 1 ft away from the battery in the spare tire well.
The 0 gauge off the negative is just a bigger ground.
There aren't any "extra" wires.
Old Aug 8, 2011 | 03:24 PM
beangrower's Avatar
that's right. i forgot you got that extra kinetik in the back. my bad.
Old Aug 8, 2011 | 05:30 PM
Fit4Spl's Avatar
Might wanna ground to the block of the motor or strut tower, will improve your resistance level on the ground side. But you know this!
Old Aug 8, 2011 | 05:49 PM
britdevine's Avatar
I upgraded the ground on the left side of the engine a long time ago
Old Aug 8, 2011 | 06:59 PM
britdevine's Avatar
Bye Bye Hatch Rattle...this was super easy to do...and the difference is night and day...took 20 minutes. I used Damplifier Pro in case anyone is wondering.
Before
After
Old Aug 10, 2011 | 12:27 PM
britdevine's Avatar
Put in New Components and Put some Second Skin Damplifier Pro on the doors
These new Massive RK6 component sets midbass were so huge I had to cut of some of the factory metal on the speaker area to get them to fit....no on will ever see it..and it doesnt affect anything at all if I ever want to put something else in.
Stock Vapor barrier
Vapor barrier Off
Deading the Outer Door Skin
Inner Door Skin
Modification - Had to cut that little bit out
Old Aug 10, 2011 | 03:23 PM
britdevine's Avatar
The Weather never cooperates with me when I want to take pictures
Old Aug 11, 2011 | 01:42 PM
britdevine's Avatar
Old Aug 16, 2011 | 09:00 PM
britdevine's Avatar
Going to be redoing some stuff soon I think....this setup is veryyyy nice though.
Another HC600Battery, another 10, a new box, and an Earthquake D3 on the subs in the next couple months are possible.
Old Aug 16, 2011 | 09:38 PM
Fit4Spl's Avatar
Unless EQ has cleaned up their act, their amps were terrible on clean power. Check Sundown out for amps, my SAZ1500D will do 2400 @ .5ohm and not break a sweat, granted I am not using it at that load but all I would have to do it recone my subs
Old Aug 16, 2011 | 11:42 PM
britdevine's Avatar
I have that EQ laying around from old school db drag in mid 90's. They arent the best sq...but I forgot what it sounded like...so I'm gonna hook it up at somepoint.
Ill see how it is when I get it going...If I hate it, I cant get another amp.
I am really loving this so far...this box/sub amp combo just smashes off 600w...actually 400 real world watts...I clamped the amp and after box rise and other stuff...its only about 400w.
Old Oct 22, 2011 | 04:24 PM
CharlotteGE8Alex's Avatar
Pandahh
SoCal Classifieds
Jul 21, 2014 02:52 PM
Vash
Dec 15, 2011 09:52 AM
markwalter
Aug 25, 2010 07:46 PM
drock305
Apr 18, 2010 12:59 PM
HB1320
Sep 19, 2009 05:51 PM
