Enkei RPF1 15" 41mm 9.5lbs
Old May 9, 2008 | 10:12 PM
xorbe's Avatar
Enkei RPF1 15" 41mm 9.5lbs -> Enkei Racing RPF1 Bright Silver Paint
Will that take the stock Fit Sport tires and look normal?
Will they rub?
Is there something lighter/better?
I want to (1) reduce the weight and (2) similar finish to stock Sport rims, ie silver/brushed look.
Thanks!
Old May 10, 2008 | 12:42 AM
x1alpha04's Avatar
yea there are lighter rims but u gotta pay more, volks make some rims that are about 8 lbs each. im planning on getting the ssr type-c's (hope im gonna be the first one with those)
Old May 10, 2008 | 04:45 AM
xorbe's Avatar
So many wheels don't spec the weight... I guess most people shop looks only. Well the lightest I've seen for 15" is 9.5lbs so far...
With stock suspension, there won't be any rub problems with 41mm offset and stock tire? I guess that's the biggest concern.
Old May 10, 2008 | 07:38 AM
fitoromocto's Avatar
Hey if you stick with the stock tire 195 55 15 event lowered, with this wheel 15-7-41mm you will not occur any rubbing issues.
Good luck and those wheels looks awsome..
Old May 10, 2008 | 08:17 PM
x1alpha04's Avatar
volk ce28 less than 9lbs
Volk Racing CE28N wheels from Upgrade Motoring
ssr competitions 15x6
3.65kg about 8lbs
SSR TYPE-C
Old May 10, 2008 | 10:43 PM
fitboy408's Avatar
I'm running 205/50/15 and they only rub in the front on BIG bumps. The rest of the time it's great!
*OK, looking for how to post pic properly..*
Old May 10, 2008 | 10:51 PM
xorbe's Avatar
3.65kg about 8lbs
SSR TYPE-C
lol wow, 2x-3x the price to shave another pound!!
Here's your photo:
Old May 10, 2008 | 11:00 PM
x1alpha04's Avatar
hey it might be worth it for some ppl lol
Old May 12, 2008 | 02:01 AM
leandro82's Avatar
Well you can go 1/2 the price of RPF1's and add 1 lb w/ Konig Heliums (10.5 lb @ 15")... They're cast wheels, but probably the most cost effective if you're trying to reduce unsprung weight.
The SSR-C, SW388, and CE28N are all in the 8 lb range but probably not worth the extra $$$ on a FiT. Unless $2k for rims is no prob to you, then it is worth it I suppose.
Old May 13, 2008 | 12:39 AM
xorbe's Avatar
(nitpick) 10.8 lbs, according to their website:
Wheels, Racing Accessories and Exhaust Systems - Konig Wheels
Nah, I don't want crazy expensive.
Choices, choices...
Old May 13, 2008 | 04:30 PM
Nerdsrock22's Avatar
I'm running the same set-up and have slight rubbing on bumps and hard turns with Toyo Proxes..
Old May 13, 2008 | 04:45 PM
xorbe's Avatar
Are you lowered at all?
Old May 13, 2008 | 05:34 PM
YeeFit's Avatar
I'm running the Enkei RPF-1s 15" +41mm offset with General Exclaim UHP 195/55VR15s and I RUB! I'm lowered on Tein S-Tech springs. I never rub in the back, only in the front. With a little massaging here and there I have gotten rid of the rubbing tho.
Old May 13, 2008 | 11:28 PM
User Name's Avatar
there is a guy at work selling his 15". He decided he wants 16" after a week.
Old May 14, 2008 | 10:37 AM
yeah I'm lowered on DF210s.
Green karma
Jan 24, 2011 02:09 PM
jjboyes06
Dec 31, 2010 06:55 PM
Warren Zock
Aug 1, 2008 10:33 PM
M-VTEC
Dec 28, 2007 01:40 AM
KnifeEdge_2K1
Dec 14, 2006 04:37 PM
