KraftWerks Supercharger Kit Info v3.0
Old May 23, 2008 | 01:39 PM
  #61
Illusive's Avatar
Originally Posted by gotfitted
hey leonine, what's so bad about the ecu seeing boost? Will it negatively affect the car's performance or longevity?
I believe it trips a CEL if it gets too high...
  #62
JDMchris.com's Avatar
I run THIS
Originally Posted by leonine
Finally...it seems that posts have been mysteriously disappearing when related to potential issues. lets not continue this because it is everyone's right to post findings/results and let other fitfreaks know what is going on. The kit is awesome! things happen and i am not bitter in the slightest nor is anyone else i have spoken to that has similar issues. we are just trying to keep everyone informed.
I went through the threads and the only posts Deleted were deleted by the OP as far as I can see.
Old May 23, 2008 | 01:55 PM
  #63
eldaino's Avatar
Originally Posted by DynamicFit
No problem,
I just did not want to be thrown under the bus, with the other guy who got totally annihilated for posting a dyno sheet that said he made 130whp or something like that. I have completely different reasons for posting up my dyno, which is merely to inform the Fit community, rather than try to show everyone how much supposed power my car is making.
sorry dynamic, i was just trying to figure out if you had upgraded injectors or not. even if you didn't wait for the hondata, i bet the power wouldb even more impressive just with the injector upgrade.
i have heard that the mugen header makes great power for a bolt on though.
Old May 23, 2008 | 01:57 PM
  #64
gotfitted's Avatar
would that cause the car to go into limp mode? If it doesn't, i don't mind driving around with the CEL on
Old May 23, 2008 | 02:02 PM
  #65
xorbe's Avatar
If I understand correctly, the system was designed so that the car does not see the boost. Probably something about CELs like the above poster mentioned, that I don't know.
Old May 23, 2008 | 02:38 PM
  #66
Hondasforlife's Avatar
I Thought That Scanguage Couldn't Read The Psi That The Supercharger Was Putting Out?....or So I Thought
Old May 23, 2008 | 02:43 PM
  #67
TeamStaNceFIT07's Avatar
Does anybody know if they are planing on developing a FMIC for the Fit kit like they did for the S2K??...hint hint...wink..wink...if there are no plans is there a way to custom IC it for more power ?
Old May 23, 2008 | 02:49 PM
  #68
xorbe's Avatar
This is over in the "KW owners thread" too, or maybe the "KW ramblings" thread... great now I get to read the same thing 3 times in 3 threads...
Old May 23, 2008 | 03:34 PM
  #69
Mr_ET's Avatar
The Scan gauge will see absolute pressure so 14.7 for ambient and then probably the 5 extra psi's if they are seen by the map sensor.
Since it was believed before that the map would not see boost, the scangauge would not have been able to give any reading of it.
Old May 23, 2008 | 04:20 PM
  #70
gotfitted's Avatar
well, the info would be valuable to the owners of the KWSC. Should anyone who owns the kit run into problems, having the solutions here or additional information would be a great benefit
Old May 23, 2008 | 04:58 PM
  #71
kmdebit's Avatar
Please don't delete...
Have some issues with the KWSC...gonna call Oscar and let him know about this.
Threw DTC's all day yesterday and today.
P0172 - Rich Fuel
put my WeaponR header on, deleted the muffler, cleared the code, and got the next one...
P0401 - EGR Flow Insufficient
double checked all tubes and pipes, everything was tight and clamped down. Cleared the code, and then got THIS one...
P2413 - EGR System Performance
wth??? Apparently all of them tend to mean rich or out of the air/fuel specs for the ECM.
Can anyone give me insight as to what might be causing these codes to appear?
Old May 23, 2008 | 05:08 PM
  #72
OJRKraftWerks's Avatar
Former Vendor
kmdebit,
The EGR codes have nothing to do with the supercharger kit. Check your connections.
-OJR
Old May 23, 2008 | 06:20 PM
  #73
jsensk's Avatar
Have any of you MT guys with the kit installed had it installed by a shop/pro mechanic? I am not implying anything at all-- just curious. I know it's "simple bolt-on" (most accounts so far don't really confirm this though), but if you have no experience with this kind of mod, then there may be a little "feel factor" or nuance that a skilled pro may (or may not, I have to say) possess.
Maybe I am implying that these issues may be a result of not knowing a few of the little tweaks or potential problems ahead of time. Oscar, JDMChris and the other testers have just been so seemingly incident free, and those guys are real heavies in this industry-- you know they installed it 100% correctly.
This inquiry also comes from a guy that would never dream of putting this thing on himself-- I have a small race shop I deal with that are the only guys I'd trust-- they do this all day everyday. And of course I don't know your skill levels so please don't take offense. I just know from suspension-related install situations I dealt with, I heard of some "do-it-yourselfers" having more issues than the race shop when installing the exact same parts. The s/c seems far more involved.
Don't get mad! Just asking. Others may be on the fence about installing themselves versus taking to a shop, so just looking for a little input or perhaps some "hindsight" perspective from those pioneering souls who have gone before us.
Old May 23, 2008 | 08:01 PM
  #74
Former Vendor
The MAP clamp clamps voltage within the stock voltage range, so the ECU never sees excess pressure. The Honda ECU typically allows pressure to go as high as 3psi before throwing a CEL. Our unit clamps at about 115 kPa. If you get a MAP high voltage code, please check your connections. The Red wire should be T-Tapped to the Green/Red Wire and the Black to the Green/White Wire. Be sure that the male spade goes firmly into the female tap.
-OJR
Old May 23, 2008 | 08:45 PM
  #75
Mr_ET's Avatar
I've installed many kits before both turbo and SC so I was not new to this but I did find that bending brake lines and A/C lines was a bit out of the ordinary.
I understand it is necessary for a belt driven S/C though so I was ok with it.
I can't say that I am a big fan of the vacuum fitting on the supercard and see that even in the instructions silicone was used to make sure the line doesn't come off.
Illusive's cel is probably due to a rich condition as well as he is still using a cat. I am confident everything is plugged in properly everywhere, the instructions were followed for everything and all sensors were plugged back in before starting the car.
I absolutely agree that this is a great kit and knew I had the experience needed for a good install but I feel the S/C belt should be about 2mm shorter and that the supercard option pales in comparison to what the hondata reflash will offer.
Old May 24, 2008 | 07:33 AM
  #76
DynamicFit's Avatar
I'm just going to throw this out there, but I have not had a single problem with the supercharger kit since I owned it. The only problem I currently have though is that they have not come out with the Hondata reflash yet, so I can put my header back on. Besides that kit is working AWESOME, stock car feel. Will have dyno charts in so you guys can see the powerband, after memorial day.
Old May 24, 2008 | 11:41 AM
  #77
jsensk's Avatar
No Hondata reflash option for AT though, right? Damn. Well anything is an improvement over the dull performance of the L15 , non FI (I have T1R header, T1R VIP axleback, T1R intake-- all of these offering some legitimate gains but on the AT-- I mean, it's nothing to get too excited about).
Old May 24, 2008 | 12:57 PM
  #78
xorbe's Avatar
Originally Posted by KraftWerks
... The Honda ECU typically allows pressure to go as high as 3psi before throwing a CEL. Our unit clamps at about 115 kPa ...
Okay, I had to bust out the conversions, but what I think this meant was the ECU complains at 17.7psi (or 3psi over atmosphere) and the clamp is at 16.7psi (or 2psi over atmosphere).
Old May 25, 2008 | 12:39 AM
  #79
eldaino's Avatar
please do, i'm very anxious to see them!
Old May 25, 2008 | 12:40 AM
  #80
eldaino's Avatar
ummmm...i don't think it has been addressed yet, though it has been asked. I would love to know, i'm a/t as well. The injector upgrade seems to be available for the a/t, so hopefully the hondata will too.
