hardwire a radar detector
Old May 23, 2008 | 08:06 PM
Spooling's Avatar
Anyone done it? What is the easiest way to do this? Shed some light please. Oh and where did you mount the detector? Thanks
Old May 23, 2008 | 11:31 PM
Spooling's Avatar
So, I thought I'd use a Add-a-circuit and attach it to the cigarette fuse. I'm not sure how to get the wire out of the fusebox. Are there any holes that I can go through from the fusebox? I'll probably mount the detector to the driver side wind shield.
Old May 23, 2008 | 11:46 PM
jdjohnson9's Avatar
I hard wired my Valentine one in through the fuse box and i ran the wire up the A pillar and through the headliner to the rear view mirror plug and hooked it up to the detector that is next to the rear view mirror. The add a circuit should work out just fine.
Old Jun 3, 2008 | 07:21 PM
Fitcapo's Avatar
Anyone do this by running the wires through a vent or under the dash? Just need some help on how to get the dash apart possibly.
Old Jun 3, 2008 | 07:40 PM
sonicsc1's Avatar
A piller is the way to go did the same way with my V1 and blue tooth mic for my d3
Old Jun 3, 2008 | 07:47 PM
gonang's Avatar
Anyone got pictures of their hardwired radar detector?
Old Jun 3, 2008 | 07:49 PM
Fitcapo's Avatar
Or rather pics of them doing it. Maybe a DIY would be awesome seeing as I have no knowledge of electrical at all.
Old Jun 3, 2008 | 10:01 PM
those radar detectors use so little power you can just wrap the wire
around the fuse terminal and push it into the fuse box.
i used a generic 2 conductor phone line to wireup my 7500.
and just tucked the cord under the a-pillar cover and up the
ceiling. no need to remove any of the panels.
for ground you can find a bolt or i used a panel clip (looks like a
binder clip without the handles) and sandwich a bare wire between
the clip and steering wheel column metal. that's how little power
it takes. should only take like 10min to do this hardwire.
Old Jun 4, 2008 | 02:44 PM
Fitcapo's Avatar
Any one want to post up some pics so I can get a better idea.
Old Jun 5, 2008 | 01:04 AM
Fitcapo's Avatar
No one???????????
Old Jun 5, 2008 | 03:30 AM
Spooling's Avatar
Yes I'll upload some pictures hopefully by this weekend...
Old Jun 5, 2008 | 06:27 AM
CuTeBoi's Avatar
Honestly, you shouldn't be asking for pictures, just do it... no matter how ghetto it is.
Old Jun 5, 2008 | 09:41 AM
Fitcapo's Avatar
Well it really isn't so much so I can tell how ghetto it is I would like to see it so I have some clue on what I am doing.
Old Jun 5, 2008 | 06:36 PM
mnapuran's Avatar
Yup.. exactly what I did. Not much for pictures, but I have a few in my Blog.
Old Dec 30, 2008 | 07:15 PM
benmunger's Avatar
im pretty good with wires and i see how you could run the wires easily without removing the pillar BUT I dont want to run the wire so it blocks the air bag.
I would like to do this properly and remover the pillar. Can anyone explain how to do this without blocking the air bag.
Old Dec 31, 2008 | 10:03 AM
benmunger's Avatar
never mind... i figured out how to remove the pillar.
Old Jan 5, 2009 | 02:00 PM
on the GE8's anyone have recommendation on which fuse to tap?
Old Jul 25, 2009 | 10:16 PM
Rubba Burna's Avatar
HID Addict
how is it done?
my V1 should be here on monday, but i want to be prepared and hard wire it first thing. ive looked around and saw people tapping into their mirror lighting, sun roof power, radio, blah blah. but those were on other cars. wat should/can i tap into through the fuse box? and how? add a circuit? same way spooling is doing? i just dont know what to tap into, and if i have to ground it or not. also, ive took pictures of how i would wire it, based on what i've read on here. tell me if im on the right track
general starting pic:
(pillar before the triangle window)
(from outside through the window, its the headliner)
and to the mirror and so on. everything ok? and what to tap into, how? and grounding needed and how? one of the bolts on firewall?
Old Jul 26, 2009 | 12:27 AM
HID Addict
midnight bump (somewhat ) there simple questiosn really
Old Jul 26, 2009 | 12:22 PM
HID Addict
noon bump
