The OFFICIAL Fit Shoes Thead! (Lug Nuts Included!)
Old May 17, 2008 | 09:01 PM
  #401
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Ughh, I didnt either. But I had the 195's since the meshies so I just kept remounting them.
My 215's are F-wordin awesome. I love real tires.
Originally Posted by Suzi_q
Those look like Integra Ls wheels. I likes.
Old May 18, 2008 | 05:21 AM
  #402
HONDAMATIC's Avatar
Originally Posted by Mx6GT89
Why such tiny tires? You shouldnt rub with those springs anyway.
ah wanted the stretchy look... the federal 595s run kinda wide anyways
Old May 19, 2008 | 06:47 AM
  #403
japspeed's Avatar
well i rub in the rear with the same springs with 195 55 15 stock sport tires on +38 and some others have also rubbed on the same set up with +40 and 195, so,i think you you will rub with those springs with 195. +40
Old May 19, 2008 | 12:25 PM
  #404
12o177e's Avatar
Taken at H.I.N. Guam! yes its the actual H.I.N. and it did really come to Guam second year in a row!
Old May 22, 2008 | 04:51 AM
  #405
titbizz's Avatar
SD MR FIT
nice fitting at ur's advan rg. mind telling me, actually what size u use and offset for this rg?
is't rubbing ur fender?
Old May 22, 2008 | 11:38 AM
  #406
SD_MR_FIT's Avatar
17x7.5 45+ offset with 205/40/r17
the only real thing i did was push up the fender lining upward to tuck it in the fender. that was the only real thing that i rubbed on. aswell as the fender clips that hold the lining, but by the time i got to those it rubbed off. i do a lot of canyon runs and i dont notice rubbing at all.
Old May 24, 2008 | 12:50 AM
  #407
titbizz's Avatar
thank s 4 the xplain ...look nice ur ride..r u using adjustable suspension or just change the spring it self..Actualy i getting 2 get advan rg as well.chrome edition...afraid of hitting the fender since the clearance are 7.5 compare i'm use b4 is 7.If that ur do..have 2 rool the fender as well b4 go for it...
thanks, bro.
Old May 24, 2008 | 11:29 AM
  #408
Drulle's Avatar
Does anybody have a pic or 2 of VBP Fit on bronze or gold 16" heliums, can't deside which color to get, also does anyone knows the weight of 16x7 heliums, thanx
Old May 24, 2008 | 12:00 PM
  #409
SD_MR_FIT's Avatar
thanks, bro.
i didnt have to roll the fender. i did the fender lining trick(push up really hard on the front fender lining till it tucked itself into the fender.
i dont carry people in the back, so i dont have to worry about it rubbing. but when i did have people, it rubbed just a tad. i just sanded down the rear bumper just a little because thats where it hit.
as long as your 45+ offset you should be fine.
Old May 26, 2008 | 12:31 AM
  #410
gawa's Avatar
Wheel: Konig Daylite
Offset: +40
Color: gold
Tire: Falken RT-615
Lowered: Yes
Setup: T1R Bmax coilovers (1st gen)
Front Rubbing: yes
Rear Rubbing: yes (I think...)
Comments: Running -2° camber in front, rubs on hard turns, rubs when I hit a large dip in the road
*not my pic*
Offset: +40
Color: gold
Tire: Bridgestone Turanza EL41
Lowered: Yes
Front Rubbing: no
Rear Rubbing: no
Old Jun 8, 2008 | 04:18 PM
  #411
HONDAMATIC's Avatar
205-40-16 rota circuit 10 bronze
no rubs stock body
Old Jun 8, 2008 | 04:39 PM
  #412
SpokanejdmGD3's Avatar
16x7+40mm Rota Slipstream Gunmetal
With Skunk lugs for extended studs
With T1R Forged Purple Lugs
Old Jun 8, 2008 | 06:20 PM
  #413
pwnstar's Avatar
16" Konig Heliums
Old Jun 9, 2008 | 12:54 AM
  #414
Bahumut's Avatar
16.7 GF1s
Old Jun 10, 2008 | 02:19 AM
  #415
junktea1's Avatar
I <3 the Rota sticker!
Old Jun 10, 2008 | 11:25 AM
  #416
that some shiny wheels.
Old Jun 10, 2008 | 12:07 PM
  #417
Will I Am fit.'s Avatar
Formerly "bitoy"
Drag dr16 15/7 +40 for my DD....
http://
Old Jun 12, 2008 | 07:00 AM
  #418
JamesBizzle's Avatar
Wheel: Volk TE-37 Cups
Offset: +35
Color: Bronze
Tire: Falken RT-615
Lowered: Yes
Setup: T1R Bmax 52 coilovers
Front Rubbing: No
Rear Rubbing: very slightly (if road conditions are bad)
Comments: Running -2° camber up front, rear fenders were rolled, and the bumper bracket was filed down. Rears are set at their lowest settings; If set 1/4" up from lowest setting, rears won't rub. Also, dampers are set at 18.
Old Jun 14, 2008 | 01:41 AM
  #419
CpE5150's Avatar
5zigen inperio... just got them today...
Old Jun 14, 2008 | 12:57 PM
  #420
Bahumut's Avatar
OMG! CPE, lower that shit!!!
