Antenna Adapter Help!
Old Jun 2, 2008 | 08:46 PM
treadLightly's Avatar
Question Antenna Adapter Help!
Where does the blue power antenna wire go that's on my antenna adapter harness? Do I need to cut a wire behind the dash. I don't see a solid blue on either of the other harnesses that I have (Pioneer and Honda). Please Help!!!
Old Jun 3, 2008 | 12:47 AM
Rod2Rice's Avatar
The blue wire on the antenna adapter needs to be connected to the Pioneers power antenna wire. Its usually either just blue, or blue with white stripe.
Old Jun 3, 2008 | 08:42 AM
I've got a blue/white on the Pioneer harness that says "Remote...I forget the rest" That must be the one, eh?
Thanks!
Old Jun 3, 2008 | 10:20 AM
Rod2Rice's Avatar
No the one that says remote is not the one you want, that is the remote turn on for an amplifier. Look in the directions for the wiring setup, there should be one for a power antenna.
Old Jun 3, 2008 | 10:36 AM
From what I can tell, there is no connection for the power antenna on the Pioneer harness. All I have left are the "remote turn on" and "mute". Should I just not use the blue wire then?
Old Jun 3, 2008 | 11:10 AM
hondaf1racing's Avatar
You hook up the blue wire on the antenna harness to the blue/white on the pioneer. Remote is also used for antenna's.
Old Jun 3, 2008 | 12:18 PM
Excellent! Thanks!!!
NjBlazin07
Feb 15, 2020 05:20 PM
vwli
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Oct 4, 2013 07:43 PM
WeaponR23
Jul 28, 2011 05:06 PM
Rod2Rice
Jul 22, 2010 11:47 AM
GodSpeed
Jun 19, 2009 04:24 PM
