The corners of the rings
Old Jul 17, 2008 | 05:33 AM
pavel22's Avatar
Because synthetic lubricants don't allow much wear on rings that is the reason for using good hydrocarbon oils during breakin, or about 1000 miles to wear the ring edges in nice and smooth.. The corners of the rings have to wear nice and rounded or tapered to hold that tiny crevice of oil between the ring and cylinder walls for minimum friction. In fact it has been known that many NASCAR engines used rings that had been machined with those rounded or tapered corners (wanna start an argument with top engine builders, advocate one) to shorten breakin and improve power. Any nicks or chips in those rings cost power and chips and nicks are what you see on those engines taken to rpm limits under load right away.
Old Jul 17, 2008 | 09:22 AM
doctordoom's Avatar
Supervillain
did you mean to post this in a thread that had to do with engine break-in questions?
Old Jul 17, 2008 | 09:59 AM
feddup's Avatar
wrong catagory?
I'm actually interested in the question but believe it's in the wrong category. I used to use Mobil 1 when Mobil 1 was new but now allow the dealership to do the oil changes with Honda oil. I still wonder if a proper break in is possible with synthetic from the beginning. I did the 5K break in that honda recomends if course.
ikutoisahobo
29
Jun 22, 2014 11:57 AM
hondafit_03
Aug 13, 2011 11:05 PM
hungff77
Oct 3, 2010 04:27 AM
parkerdt
Nov 9, 2009 07:15 AM
KnifeEdge_2K1
Feb 19, 2007 01:29 AM
