Fit headlight bulb size..!
Old 05-21-2015, 04:22 AM
IQBALLK's Avatar
HI..
I thought my gp5 (2015 February) had H4 (9003) bulbs. bought pair of cree led h4's from ebay. but the stock bulb is different than h4. can any one pls confirm is this the head bulb..?
Old 05-21-2015, 04:28 AM
IQBALLK's Avatar
stock bulb was SYLVANIA HB3 (9005) 2 PIN SINGLE BEAM YELLOW.
Old 05-21-2015, 04:52 AM
Black3sr's Avatar
These sound like your signal lights.
Old 05-21-2015, 06:37 AM
IQBALLK's Avatar
if it is.. wheres the head bulb located..
Old 05-21-2015, 07:01 AM
Black3sr's Avatar
Is the one you took pic of behind the signal light or not? If so then the high and low ones are to the outside. Anything in your manual?
I did not realize you have separate high/low lights on the GK.
Old 05-21-2015, 07:26 AM
Uncle Gary's Avatar
Wow, that's a bit different setup from the Fits we get here in the U.S. We just have a single headlamp on each side with a 9003 (H4) dual beam lamp.
Old 05-21-2015, 08:14 AM
IQBALLK's Avatar
please check this pic..
Old 05-21-2015, 11:25 PM
IQBALLK's Avatar
some more pics...
Old 05-21-2015, 11:31 PM
IQBALLK's Avatar
Old 05-22-2015, 04:05 AM
Black3sr's Avatar
Well that is interesting but does not help identifying which bulbs you need. If it is not in your manual then I would just call a dealer and ask them.
Old 05-22-2015, 09:04 AM
xxryu139xx's Avatar
one of your pics is of a HID ballast i think. question is why replaced HID with LED?
Old 09-06-2023, 11:23 PM
icyswish's Avatar
Any update on the bulb size of gp5 headlight low beam and high beam?
Old 09-08-2023, 06:20 PM
You can remove them and look at what is printed on the bulb base.
Old 10-17-2023, 09:43 AM
icyswish's Avatar
My main concern is i bought a pair of those projector headlights but i noticed that the right projector didnt have low beam drive unit, and i cant find one here in ph
THE_DON
109
08-08-2023 05:03 PM
mav238
01-14-2015 02:59 PM
drock305
02-09-2010 08:06 PM
713_fit
10-18-2009 01:06 AM
urbnzeus
06-01-2009 10:26 PM
Quick Reply: Fit headlight bulb size..!
