Test pipe+b-pipe+axleback=fart can?
Old Sep 4, 2008 | 02:47 AM
joquio's Avatar
Ok here is the deal guys,
I just installed the T1R test pipe+Spoon B-pipe I got from a local member.
I already have the Aspec axleback. After I installed the parts I took the car for a quick spin. Now it was nightmare.... I felt soooo embarassed for the whole night. The car got noticable louder and I could understand that but whenever I "stepped" on the gas a bit harder the car sounds like it's gonna explode lol really high pitched ricer fart can tone.
I took the car the next morning to have the stock cat and stock muffler installed back on because I couldn't stand the sound any more seconds....
tone is drasticly reduced and I will probably have my aspec axleback installed back on tomorrow to see if it is still ok.
My point is, is it normal when you have the test pipe(cat delete) installed?
Or could it be exhaust leak? I always hear this pssshhh sound when I step on gas but my friend check for me and told me it's because of the straight through flowing b-pipe I have.
PS: Is there suppose be a gasket between the testpipe and b-pipe? Because I could find my stock one as I have looked on both end and I looked up on bernardiparts and they had one between oem cat and b-pipe in the image.
Any input ?
Old Sep 4, 2008 | 03:01 AM
Fa1's Avatar
Fa1
Sounds like a leak to me. You're suppose to have gaskets between all pipes.
Old Sep 4, 2008 | 03:07 AM
Spooling's Avatar
high pitched? mine sounds really low pitched. but running a test pipe on a mild modded Fit is kinda embarassing already. you can always go FI for quieter exhaust.
Old Sep 4, 2008 | 03:08 AM
spoonek4's Avatar
I gotta see your car in real & see if there's any leak, but it's hard to contact u on MSN.....
It's quite normal if it gets high pitch loud if u use an Aspec muffler though, same thing with APEXi N1 due to the big piping on the axleback part. If u want it to be quieter I suggest u to install the stock cat back on or some other muffler(like Mugen_Dom's Mugen muffler) on to your car.
Old Sep 4, 2008 | 03:22 AM
joquio's Avatar
Do you have cat delete installed?
Old Sep 4, 2008 | 03:23 AM
joquio's Avatar
I do have gaskets on all EXCEPT between cat ---> B-pipe I couldn't find the stock gasket? (burned?)
Old Sep 4, 2008 | 03:25 AM
joquio's Avatar
Thanks for the input jacky, I still need to make an appointment with you for the alignment.... let me hop on msn now
Old Sep 4, 2008 | 03:26 AM
Spooling's Avatar
megan header->t1r test pipe->t1r b-pipe->t1r 50s
it sounds really low profile under 3k rpm, then it goes berserk after that
Old Sep 4, 2008 | 03:27 AM
Fa1's Avatar
Fa1
If I remember correctly I think the stock gasket was a donut gasket so you need a flat gasket which would come with the exhaust, but since you got it second hand you'll need another one.
Old Sep 4, 2008 | 03:28 AM
joquio's Avatar
Like really loud and raspy? My ears almost explodes if I step on it really hard with the test pipe installed.
Would having a aftermarket header quiet things down?
Old Sep 4, 2008 | 03:35 AM
Spooling's Avatar
loud, deep and vibrant, not raspy. yea having a hi-flow header will tune the volume down a bit. but you will lose a lot of low end torque.
gotta save up for turbo
Old Sep 4, 2008 | 03:41 AM
Fa1's Avatar
Fa1
It's probably just better to keep the stock cat on if it's too loud for the few hp you gain.
Old Sep 4, 2008 | 03:43 AM
joquio's Avatar
Thanks for the input!
I will look into getting a flat gasket, any idea where to get those?
Old Sep 4, 2008 | 03:45 AM
Fa1's Avatar
Fa1
Any auto-parts store should have them. What's the inner diameter of the spoon b-pipe btw?
Old Sep 4, 2008 | 03:46 AM
joquio's Avatar
HKS or Greddy?
It's hard to resist getting one when you already have the funding
But it's just not the right time for me to turbo this car yet
Old Sep 4, 2008 | 05:55 AM
joquio's Avatar
so one more question,
1) oem cat+Spoon b-pipe+aspec axleback
or
2) T1R testpipe+oem b-pipe+aspec axleback
which one would yield more gain?
Old Sep 4, 2008 | 08:49 AM
GD3-Fit's Avatar
I <3 SPOON
or
it's hard to say
i'd think they are maybe about equal
i have a gasket between my TP and B-pipe
my exhaust is a little loud but if i take the spoon n1 off it's super loud
-Ricky
Old Sep 4, 2008 | 12:06 PM
isthata_scion's Avatar
or
I think it would make more sense to do option #1. you dont want less restrictive testpipe, then stock bpipe, then a less restrictive axleback. Just a thought though.
Old Sep 4, 2008 | 01:51 PM
Mr08FiT's Avatar
Same...
This is exactly why I sold my Test-Pipe, I have A-spec: header, b-pipe, axel back. When I had the test-pipe on there was no header but the sound that came out the that exhaust was just awfull. I mean, to quote "Fart can" raspy. So I sold test pipe got header, leave everything else don't worry about power gains. Leave stock cat, and just grab a header. IMO
Old Sep 4, 2008 | 02:14 PM
fung88's Avatar
same reason why i sold my testpipe actually! it was just wayy too loud for my commute!
