will these rub?
Old Sep 10, 2008 | 11:25 PM
brdss's Avatar
will these rub?
OK, stock 15" rims on a 07 sport. Can I go from a 195/55R15 up to a 195/60R15 without it rubbing? Would like to soften up the ride with a higher sidewall. What is the tire clearance on the stock set up? I know the speedo would be off about 3% but that is a good thing! I checked it as it is with the stock tires (used a calibrated radar gun) and it is reading about 3%higher than it should anyway, so it would actually be right on the mark!
Iknow, all you yungins want to go as low a sidewall as possible for the looks. Not my thing. Just want to soften the ride during the commute!
Thanks!
Old Sep 10, 2008 | 11:34 PM
B1str0's Avatar
RubberBabyBuggyBumpers
stock height yes ... lowered on any type of spring u will rub on dips
Old Sep 10, 2008 | 11:43 PM
brdss's Avatar
completely stock height! not lowered or anything at all.
Old Sep 10, 2008 | 11:54 PM
B1str0's Avatar
you''ll be fine
Old Sep 11, 2008 | 09:23 AM
mahout's Avatar
Thanks!
I doubt 195/60x15 will rub though the tire is 24.2" diameter compared to stock 23.4" (3.3% surprise) That higher sidewall coupled with a little lower air pressure should certainly be softer riding but how about your mpg? Its likely to be worse, corrected for thr odo error. I might have preferred 185/60x15 or even 175/65x15's. My snow tires are 175/65x15's and my wife thinks they'r much nicer than my 205/40x17's; and I do get better mpg compared to the 205's. Naturally cornering sucks tho. As for the young'uns, I'm 71.
NotBlake
Jan 23, 2015 09:59 AM
mdsniper7
Oct 16, 2010 04:19 PM
sandblasted
Sep 15, 2010 06:38 PM
brittwin
Mar 31, 2009 04:19 PM
