View Single Post
  #19 (permalink)
Old 09-24-2008, 01:49 PM
YeeFit's Avatar
YeeFit YeeFit is offline
YeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to liveYeeFit relies on Rep Points to live
Quote:
Originally Posted by explosivpotato View Post
You don't need two maps, just tune the f-con for your max boost setting. The tune is (usually) a manifold pressure VS. RPM grid, so if for whatever reason the boost doesn't hit the maximum tuned limit, the computer doesn't care. It just adds the correct amount of fuel / timing retard for whatever boost you're at.
I was just gonna do what kelsodeez said, but after talking to my local speed shop I am gonna look for an EBC or MBC. They wanted $100 for a Tial wastegate spring... that's a bit ridiculous IMO.
I'm gonna probably get the Greddy Profec B Spec II EBC. My friend highly recommends it and he can set it up with ease.
If I went with a spring, I only have a couple of choices.. 0.5 bar (7.25psi) or 0.6 bar (8.7psi). I'd probably go with the 8.7 psi spring, but I think I'd prefer to be able to adjust my boost to where I prefer it to be.. and all the extra features of the EBC are appealing too...
