Getting a Sub
Old Oct 5, 2008 | 08:59 PM
Nighthawk_GD3's Avatar
Getting a Sub
I am wanting to add a little bass to my fit, as you all know the fit has shit for bass from honda. I am not wanting anything rediculous, just a lil extra bass. Anyone have any suggestions for a sub and amp?
Old Oct 5, 2008 | 10:21 PM
shazaam's Avatar
infinity basslink is what a lotta people have done all in one, just gotta run the wire and it's been recommended quite a few times. Doesn't give you the wonderfullness of tummy rumbles or a massage but does well to add a little more punch and low notes to the sound system fer sure,
Old Oct 6, 2008 | 12:14 PM
MPGASAP's Avatar
Have you upgraded your stock speakers (you may not need a sub)? Stock head unit? What's the budget? Will you install it yourself? Are you handy with tools? Hit or rumble? Would you tolerate a box twice as big for deeper bass (ported boxes are not good projects for amateurs and should be purchased for the sub). Post a response with a little info and we'll be able to help you find the best gear.
The Infinity Bass Link is a great suggestion, but it has no "hit" what so ever. It sounds like a high grade stock system which is about as good as a low grade aftermarket system. If you want a very tiny bit of mid-range woofer style bass it is perfect though. It is rated at 200 watts, but sounds like 75 out of a component system.
http://www.crutchfield.com/app/produ...earch=basslink
Old Oct 6, 2008 | 08:42 PM
vince's Avatar
get a 10" realm audio sub or 12"
they are sq subs and sound very good while having that thump you want.
Old Oct 6, 2008 | 08:47 PM
abstrakt thawt's Avatar
rockford generally makes a good product at a lower price a bazooka tube would be the simplest
Old Oct 6, 2008 | 11:19 PM
Injundon's Avatar
you'll get more opinions than there are ants at a picnic. What's your budget and what are your goals. Do you mind having a box in your trunk al the time. You need something low-key. is space an issue.
Rinzler
May 22, 2013 01:48 AM
Wahe
Apr 14, 2010 09:36 AM
whoa42
17
Nov 15, 2009 07:21 PM
blazej
Aug 5, 2009 08:00 PM
shazaam
Jul 26, 2008 10:18 AM
