Modifications--does anything really increase MPG?
Old Oct 5, 2008 | 09:01 PM
  #141
mahout's Avatar
Originally Posted by Skierdood
I put a K&N short ram, and 15" rota circuit 8's with 195 55 R15 Yokohama S.drives on my car and here is the results. I did three tanks before the intake/wheels and calculated my mpg, then 3 tanks after the install. Both times using regular 87 octane 10% ethanol unleaded gas.
For the pre intake/wheels tanks I went 934.5mi consuming 25.66 gallons of gas, netting 36.42 mpg combined about 70 percent local roads 30 percent highway.
Then for the 3 post intake/wheel tanks I went 912.7 miles consuming 24.2 gallons of gas netting 37.71 mpg.
There was no change in my driving style and it was a similar blend of highway and local road miles for each set. I was slowly accelerating to 2500rpms for my shifts and cruising around 45mph as much as possible. I would coast to lights in 5th gear with no gas as well. I was not doing anything too drastic though.
The problem with your experiment is that statistically you haven't proven much. You need to take the individual 3 ankfuls nd calculate the 3 sigma variations of both sides of the result and see if there was at least 90% assurance of a difference.
Its a common error by the globval warming proponents because they have no idea what the temperature range of theearth for the last 100,000 years, only the last 50. All they have i a trend and trends are not surety.
For example, I recently took off the inlet iping and substitted aair horn. My last two tanks have been 2.5 mpg improved. Not necessarily from the air horn (velocity stack) - yet. I need about 6 tank fillups to compare to the last 6 fillups before and even then because the air temperature has changed (down) it may not be indicative then.
But hold on and when you clean the filter and re-oil it be very careful to do it properly. Excess oil from reinstallation of even new K&N's have been known to foul the MAF sensor.
cheers, and good luck.
Old Oct 5, 2008 | 09:12 PM
  #142
manxman's Avatar
GD3 Fits DO NOT HAVE MAF SENSORS. Only GE8's have them.
  #143
Skierdood's Avatar
Yeah I was just stating that in the real world my consistent 36mpg has now increased to about 37. I know its not perfect but it was just a rough assumption.
Bossharp
Mar 23, 2018 09:33 AM
jcschlic
Dec 10, 2014 02:30 AM
ImPuLsIvE.ca
Nov 26, 2014 02:19 AM
Rob22315
Jul 25, 2009 10:19 PM
Sam Misled
Apr 27, 2008 12:13 PM
