Umm is anyone else going at 80mph at 4000rpm??!?!
Old Nov 4, 2008 | 10:02 AM
  #61
JCLW's Avatar
Originally Posted by kylerwho
do you know how they calculate this for the rotory motor?
Rotor tip speed.
Old Nov 4, 2008 | 03:09 PM
  #62
mahout's Avatar
Originally Posted by JCLW
Rotor tip speed.
Feet per minute is calculated the same by multiplying the circumference of the roatry chamber base circle in ft by rpm.
The limit is hardly 2500 orr 3500 fpm however, as thee is no acceleration and deceleration to put the enormous strains on the bearings.The limit there would probably be the fpm in which the surfaces could carry lubricant between them. As a guess I would say 8000 fpm.
Old Nov 7, 2009 | 03:16 AM
  #63
Occam's Avatar
This thread amuses me.
For what it's worth, my Element was a 5MT, and in 5th gear, gained 20 MPH per 1K revs. 3K at 60, 3.5K at 70, 4K at 80. I test drove a first-generation Scion xB back in '06: I noted that it was the same.
On the other hand, at 75 mph, my Ninja is running happily at 5500 RPM. At 75, my wife's lil Ninjette (a 250cc Ninja) runs at almost 10,000. Mine redlines at 11,000, hers at 13,000. They have smaller pistons, and short strokes, but otherwise aren't terribly different than any car engine. Mine (a Ninja 650R) is a DOHC fuel-injected parallel twin.
With a sportbike in the garage, I have no need for a car to go fast! The 650R will hit 60 in under 4 seconds A slow Fit is perfect... and gets almost the same mileage. (45 mpg or so under most conditions)
Old Nov 7, 2009 | 04:23 AM
  #64
Fitcious's Avatar
wow you brought an old thread back from the dead! hahaha
Old Nov 9, 2009 | 11:42 PM
  #65
Schadenfreude's Avatar
Originally Posted by Darkstars
not sure about you guys but I've never seen an 80 MPH speed limit... problem solved
West Texas.
Old Nov 10, 2009 | 02:37 PM
  #66
chrisakasparky's Avatar
Going to the beach from Orlando = driving 100mph
Old Nov 12, 2009 | 03:32 PM
  #67
novascroller's Avatar
Originally Posted by sam21
WTFF?!
I've noticed this ever since i bought the car but always forgot to bring it up here.Is it just me?!!?80mph at 4000 and 65-70at 3500 is NOT cool.Both for mpg and comfort.
Is there a TSB about this from Honda?
slowing down may be a good idea.
Old Nov 12, 2009 | 04:32 PM
  #68
B1str0's Avatar
RubberBabyBuggyBumpers
^^^ the op doesnt have a fit anymore lol
Old Nov 12, 2009 | 05:57 PM
  #69
Red 05's Avatar
The highest I get up to anywhere in town is maybe 75, and that's if I'm trying to pass someone on the one mile highway I take on part of my commute to work. The rest of the time I'm driving along at 65 MPH closer to my house, and around 45 when I get closer to my work. I knew the MT reved higher, but I also knew the MT would be alot more fun to drive than the AT. Besides, paying 22 bucks for a fill up is awesome anyway.
Old Nov 12, 2009 | 07:14 PM
  #70
Selden's Avatar
WTFF?!
BFD. My Honda N600 car turned 5000 rpms at 70 mph. I put 93,000 miles on it before I sold it. My R1100RT motorcycle turns about 4500 at 80, which is relatively low RPMs for a motorcycle engine.
Old Dec 2, 2009 | 06:56 PM
  #71
jelliotlevy's Avatar
WTFF?!
I suggest you never drive a Honda S2000. Typical rpm's on the highway are 3300 rpm at 60, and nearly 4500 rpm at 80. Very high revving engine, and designed to take it, as is the Fit's engine. The Fit with automatic transmission is geared a bit longer, giving roughly 2100 rpm at 60, and under 3000 at 80. By the way give the Fit engine a special gold star for quality: the overhead cams are driven by a chain, rather than the cheaper and very ubiquitous belt drive.
Old Dec 2, 2009 | 07:04 PM
  #72
Selden's Avatar
I hadn't realized that; replacing the valve train belt was an expensive bit of required maintenance on my last two cars (Nissan Quest V6 and Subaru Forester).
Old Dec 2, 2009 | 07:54 PM
  #73
Konservative's Avatar
Originally Posted by Chikubi
Far from it -- around here do anything less than 75 and you will get creamed by the semis, etc regardless that the limit is 65. That's reality, and I'm sure other locations have similar circumstances.
In CA this has gotten crazy. No one goes the speed limit. Highways are all 80+ and cities are usually speed limit +10 mph.
RE: the high rpm's changing your final drive ratio would probably help that situation. But i do not know of any mass produced FD gears, so it would probably be an expensive custom. IIRC your acceleration would suffer from this mod though.
Old Dec 3, 2009 | 10:43 PM
  #74
JCLW's Avatar
Or run larger tires. I run 185/60R15 in the summer on my GD3 which brings my engine speed down 3% for any given road speed - but of course my speedo and odo are off 3% as well.
fstyle751
Feb 22, 2012 10:03 AM
klutzyfool
Sep 5, 2010 11:51 AM
FittJedi
May 2, 2009 08:12 PM
martymcfly
Oct 10, 2007 04:59 PM
Chopface
May 4, 2005 11:16 AM
