JDM coilovers vs. USDM coilovers
Old Nov 17, 2008 | 12:04 PM
ChrisG's Avatar
I need to know if anyone can give me any information regarding the differences between JDM coilovers and the USDM GD3.
I need to know if there are any differences in bolt sizes etc. etc.
Any information would be greatly appreciated.
Old Nov 17, 2008 | 05:55 PM
Fa1's Avatar
Fa1
The jdm front strut that bolts to the hub assembly are smaller than usdm.
Other then spring rates, I think those are the only differences.
Old Nov 17, 2008 | 06:34 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
I was told it was the rear bolt, and its only the rear shock bolt thats a different size.
Its smaller.
DO A SEARCH, CHRIS!
Old Nov 17, 2008 | 06:52 PM
JDM_DOHC_SiR's Avatar
Thumbs up
I got you covered Chris.... give me about 1hr and I`ll get the 100%info that you need..... I told you what you need on the front but I`m waiting on the rear
Old Nov 17, 2008 | 07:02 PM
OK 1hrs up..
The part # crossed and they are the same bolt in the rear.. so you`ll be fine.. you`ll just have to modify the fronts
Old Nov 17, 2008 | 07:29 PM
doctordoom's Avatar
Supervillain
Originally Posted by JDM_DOHC_SiR
OK 1hrs up..
you sir, are clutch like encyclopedia brown.
Old Nov 17, 2008 | 07:50 PM
Thanks!!
Old Nov 17, 2008 | 08:17 PM
SHG_Mike's Avatar
the difference is the bolt size. youll have to drill the front holes to 14mm and in the rear you will have to use a washer or to to space the shock and the rear H beam. the opening is larger in the usdm so youll need a couple washers, but the bolt is fine.
I just installed my Mugen SS
Old Nov 17, 2008 | 08:19 PM
ChrisG's Avatar
Hey Mike,
PM me if you might be interested in another custom coilover setup.
onetwothree
Mar 14, 2015 11:53 AM
untx3
Oct 26, 2011 01:01 PM
fitinfit
Sep 13, 2007 11:52 PM
kidynomite
Aug 7, 2007 09:45 PM
Elem3nt
Nov 12, 2006 06:53 PM
