HFP wheels on Fit
Old Nov 18, 2008 | 01:32 PM
Fithonda2008's Avatar
Talking HFP wheels on Fit
Hello, does any one have the HFP wheels on their Fit?
What PSI do you have for the tires. I set it at 51 PSI according to the tires. But it pick up alot of road noise. But supposely if you set it according to the tires, you save gas right? Thank you to any one that reply.
Old Nov 18, 2008 | 02:57 PM
moegenki's Avatar
Whoa, you're supposed to follow the psi numbers on the chassis sticker on your door jamb when you open it and not the max psi on the tire.
Old Nov 18, 2008 | 03:43 PM
Now, wouldn't that be for stock spec. If you were to follow the chassis sticker?
Old Nov 18, 2008 | 04:45 PM
Masterdebater's Avatar
dude...most id put it at is 40 since they are a low pro tire....ull destroy the tires at that psi
Old Nov 18, 2008 | 06:20 PM
wait4thefit's Avatar
i have them i run 30psi
AnlDyxp_GD3's Avatar
i have the HFP wheels with Falken ZE-912 205/45/16 and i have them at 35 PSI i think.
Old Nov 19, 2008 | 08:59 AM
kamakurakid's Avatar
I bet the car handles nicely. Harsh but nice. I would be interested in your new impressions once you have let out 20 PSI.
Old Nov 19, 2008 | 03:03 PM
But the PSI I put is according to the tires printed.
Old Nov 19, 2008 | 03:05 PM
Yes it does handles very nice. But I hear alot of road noise. What PSI are you using?
Old Nov 19, 2008 | 05:11 PM
You are located in Rosemead, CA?
51lbs of tire pressure now, so I bet a really hot afternoon in the summer will be interesting. You ought to take a drive to Las Vegas in July, see if the tire sensors are working right. Remember, the ditch is to the right and steer into a skid, not away.
Old Nov 19, 2008 | 09:04 PM
winkydink's Avatar
The 51 lbs listed on the tire is the maximum inflation pressure. In other words the most you can put in and the tire mfg will guarantee they won't go KABOOM! You want a lot less than that.
Like the previous poster said, start with what's printed on the door jamb and then tinker over time with small adjustments up or down.
Old Nov 19, 2008 | 09:13 PM
FitVic's Avatar
I run 32PSI on mines. 51PSI is kind of crazy man lol I ran 40PSI and i couldnt stand it plus the handling seem a bit off for me to drive with.
EDIT: Someone correct me if I'm wrong. If you had a really high or really low PSI wouldn't that mess with your tires tread wear??
utsug
May 5, 2017 03:27 PM
umiekun
SoCal Classifieds
14
Jun 7, 2012 04:32 AM
Crawly
May 7, 2009 02:54 PM
andrew00
Feb 27, 2008 12:21 AM
Crawly
Dec 24, 2007 07:24 PM
