2008 Factory Alignment Specs? Help!
Old Nov 20, 2008 | 01:10 PM
mnapuran's Avatar
Did searching but didn't find a clean cut answer in one place showing the factory alignment specs. None of the local shops have 2007/08 info yet, and hate to go to the dealer.
Thanks!
Old Nov 20, 2008 | 02:48 PM
jeffquach's Avatar
it's in the manual mike..forgot what page though
Old Nov 20, 2008 | 02:49 PM
cojaro's Avatar
The front camber will be about 0*, +/- 0.5*
The rear is probably gonna be about -1* +/- 0.5*
That's assuming you're on stock suspension, though.
Last edited by cojaro; Nov 24, 2008 at 01:44 PM. Reason: Forgot to mention which suspension angle DOH
Old Nov 20, 2008 | 05:20 PM
trancedsailor's Avatar
You need a camber kit front and rear or they'll only adjust your toe. I had the same issue. I'm riding on vogtland springs, stock shocks for 2 weeks now ;/ they'll be fine for a month or two I'm guessing.
Old Nov 21, 2008 | 09:28 AM
mnapuran's Avatar
I'm not really looking for recommended settings... looking for factory settings.
Old Nov 24, 2008 | 10:50 AM
FITtin''s Avatar
Is the camber kit from Honda or an aftermarket company?
Old Nov 24, 2008 | 01:02 PM
Originally Posted by cojaro
The front will be about 0*, +/- 0.5*
really? negative numbers are toe-out condition. just looking
at the rear there's plenty toe-in.
Old Nov 24, 2008 | 01:47 PM
cojaro's Avatar
I'm retarded. That's camber. I haven't a clue what the stock toe alignments may be.
Old Nov 24, 2008 | 05:04 PM
doh, i was thinking toe for some reason but yah, if it is camber
im sure that's about right.
somewhere in my FitBlog i have the factory spec vs my car's measurements.
(in the newb section).
toda_power
May 19, 2017 08:03 AM
KeithDigital
Feb 1, 2012 11:42 AM
die_lawn
15
Aug 31, 2009 04:23 PM
CrystalFiveMT
Feb 5, 2009 07:59 AM
cheebz
23
Jan 7, 2008 11:33 AM
