Clutch Problems?
Old Nov 21, 2008 | 07:22 PM
F0NIX's Avatar
The only problem I have is that I can't find the clutch pedal...
...Oh! Wait, I have a CVT
But at least I can brag about that I have more clutches in my car than most of you have. even if I dont have a clutch pedal. I think there is 5 clutches inside the CVT tranny. And they are all smooth as.... ice?
Old Nov 21, 2008 | 10:24 PM
1coolride's Avatar
my clutch doesn't really make any noises, but it does feel lower than when i first bought the car 1 year ago. i took it in to the honda dealership for service and they said theres nothing wrong with my clutch. they said its normal for it to feel lower.
Old Nov 22, 2008 | 10:46 AM
Flyin172s's Avatar
It's funny how many problems are 'normal' when you take it to the dealer... my passenger door panel rattles now, dealer said that's normal. the A/C doesn't cool down if it's above 85 degrees outside, dealer said that's normal, the wheels fall off at highway speed, NORMAL! lol
Old Nov 22, 2008 | 01:46 PM
doctordoom's Avatar
Supervillain
so true. and if it's not normal, then they can't reproduce the problem lol.
Old Nov 22, 2008 | 01:49 PM
ricohman's Avatar
The next time one of you takes your Fit in for this complaint tell them to check the pedal height and the freeplay in the pushrod under the car.
It may just be a matter of adding a bit of freeplay to solve this problem.
A cold clutch will chatter if its not completely engaged.
Once warm it will act as normal, but I would expect this to get worse as the disc wears.
Old Nov 25, 2008 | 04:22 PM
cathyrob's Avatar
Let me add my name to the list of concerned owners. I have a '07 with the same symptoms of chattering especially when cold. However, this did not develop until about after 30,000 miles. Can't we somehow get Honda to fix this before the warranty wears out?
Old Nov 25, 2008 | 07:08 PM
ricohman's Avatar
The next time you take it in, get them to check the amount of freeplay.
I would bet that its not enough.
And if it's normal then the pressure plate is faulty. There is no way the disc should be slipping with low miles unless you've ridden the clutch.
Old Nov 25, 2008 | 07:24 PM
kancerr's Avatar
a little chatter when engaging is fine as far as i know. you should hear my car when engaging gears since the lightened i installed, if its cold it sounds like its going to fall apart ;D (which is normal for it to chatter more than stock).
Old Nov 26, 2008 | 09:52 PM
ricohman's Avatar
Chatter is slippage of the disc between the pressure plate and freewheel when the release bearing is disengaged.
Not the same as a slipping clutch and not the same as a noisy grabby clutch.
The chattering sound is actually made by the dampers in the clutch disc compressing and releasing. Its worse with spring type dampers but I would think the Fit would have rubber cushions.
I would really like to go for a test ride with someone and actually listen to this. None of the Fits I know have this problem though!
Old Nov 27, 2008 | 08:53 AM
kancerr's Avatar
i still stick with my statement a little chatter is fine. if i need to i can go get my flywheel install papers from fidanza and qoute the explanation of chatter? it clearly states that some chatter is okay stock and with the lightened flywheel it would chatter more but in no way means that it is faulty or will break.
as for the other things i never said anything about it being the same as a slipping clutch. i was strictly talked about "chatter" and nothing else. do not put words in my mouth ;]
Old Nov 27, 2008 | 10:03 AM
1coolride's Avatar
i know right.... it's like they don't wanna fix the problem or something
Old Nov 27, 2008 | 05:59 PM
  #32
ricohman's Avatar
Originally Posted by niaz12
doubt that the same thing will be on the new Fit. It would seem to me to be much simpler to incorporate it it into the slave or master. The presence of this thing may explain why sometimes when I clutch there is not a complete disengagement and when I shift
Are you refering to an adjustment pushrod?
There are usually two. One on the master to set up the pedal and one on the slave to adjust for disc wear as needed.
Old Nov 27, 2008 | 06:01 PM
  #33
ricohman's Avatar
Any chatter is not normal.
Lots of chatter will eventually fracture a spring damper or the damper seat in the disc. Then the bits start flying around inside the bellhousing.
Either way, if my car had chatter I would fix it.
Old Nov 29, 2008 | 11:11 AM
  #34
cathyrob's Avatar
Ricohman-- Thanks for all of your comments. I'd love you to test ride my car. Do you live anywhere in the L.A. area?
Old Nov 29, 2008 | 05:37 PM
  #35
ricohman's Avatar
Nope. I live waaay up north!
Old Dec 1, 2008 | 08:24 AM
  #36
7red7's Avatar
I've noticed the chatter a while back. It's subtle, and only makes the noise when I'm barely dis-engaging the clutch pedal to ease forward from a stop (like when you're in a drive-thru and have to move up, or heavy stop and go traffic). I've had it checked by the local dealership, and have been given a clean bill of health. My '08 Sport has just over 6,000 miles and they did the work under warranty.
Old Dec 2, 2008 | 02:19 PM
  #37
shy34's Avatar
next time you visit the Calgary area you can test drive mine. Next oil change I will be making a complaint. I dont care if the drive train is cold, it should''nt do that.
Old Dec 5, 2008 | 08:02 PM
  #38
ricohman's Avatar
Is this transmission noise or clutch noise?
The reason I ask this is a co-worker of mine just got a new (to him) R1200GS a couple of weeks ago. That's a BMW dual sport touring bike.
Anyway, he was complaining of clutch chatter and I got to take it for a spin.
What he is interpreting as clutch chatter is actually noise from the transmission as the bike is geared tall in 1st.
When warm most of the noise goes away.
This noise is actually backlash and there is little to be done about it. I wonder if what you are hearing is trans noise?
Old Feb 12, 2009 | 10:08 PM
  #39
emi's Avatar
emi
Here's my 2 cents. I have clutch shudder/chatter in first gear when cold. I had the exact same problem in my 1990 bmw, my 2000 bmw, and my 2000 toyota echo. The only fix is replacing the clutch disk and pressure plate. Additionally, the flywheel must be turned or replaced. There is no other fix!
The problem starts after the clutch disk is overheated. Material from the clutch disk transfers unevenly onto the pressure plate and/or flywheel friction surfaces. This is the exact same process that brake pads and rotors go through when over-heated.
Performance brake pads require a break-in procedure during which they are purposely overheated to cause this pad transfer onto the rotor surface (otherwise they don't work well).
Honda under-engineered the drive-train to save money and weight. Depending on how aggressively you drive, you may or may not experience this problem.
Old Feb 14, 2009 | 08:34 PM
  #40
kancerr's Avatar
could this just be the throw out bearing? i replaced my clutch a few months back and had to use the old throw out bearing. its in fine shape, but i am getting noise from it...is it a creaking noise? if so i wouldnt worry much about it.
