FIT-Vendor Sponsored Group Buys and Sales Organize group buys to get discounts. Only Forum Sponsors may post group buys in this sub-forum. Forum Sponsors will have "FIT Vendors" in their user title and have gone through a screening process by FIT Freak staff.
KraftWerks Fit Supercharger Kits (Manual and Automatic!)
Old Nov 25, 2008 | 06:29 PM
OJRKraftWerks's Avatar
Former Vendor
Fit MT Base Kit
Included Items:
• Rotrex C15-60 Supercharger at 5 PSI* with KraftWerks Supercharger Insert
• Rotrex Self-Contained Oiling System with Oil Cooler
• KraftWerks Recirculating Bypass Valve
• KraftWerks Automatic Belt Tensioning System
• KraftWerks SuperCard Engine Management Unit and MAP Stabilizer
• KraftWerks Aluminum Intake and Discharge Piping
• KraftWerks Silicone Hoses
• KraftWerks Oiled Air Filter
• KraftWerks 5-Rib Belt
• KraftWerks Brackets and Hardware
In Stock!
Fit AT Base Kit Included Items:
• Rotrex C15-16 Supercharger at 5 PSI* with KraftWerks Supercharger Insert
New Release! In Stock!
*Boost level is determined at sea level, and can change depending on modifications, weather, altitude, etc.
-CARB Pending-
About KraftWerks:
KraftWerks was started to house all of our Rotrex-powered supercharger kits by Jackson Racing. We believe the Rotrex product will be able to grow with this brand into the future.
KraftWerks is made up of us at Jackson Racing, with Oscar Jackson Sr. at the helm and the rest of our original Jackson Racing supercharger engineers. The same quality and technology that you have known of JR, will be with KraftWerks, and will be better than ever. We have improved our supercharger design techniques and have learned quite a bit on the Rotrex supercharger from recent testing.
KraftWerks will establish its own distribution by the time of the release of our new kits. No other companies will be responsible for the distribution of KraftWerks supercharger kits.
We appreciate the support of the Fit community very much! We are very excited about our new venture, and hope the Fit community is ready for some boost!!
The Fuel Electronics:
The SuperCard is a small digital electronics unit that is able to extend injector duty cycle in boost for the given condition. The SuperCard is not a "basemap" to get you to a dyno or to "get you down the road." Also, the SuperCard really isn't a "piggyback" by traditional standards.
We spend a lot of time testing to get the electronics to work perfect across a whole range of situations; much like a typical OEM manufacturer tests their cars to work across a range of situations. We take pride in our SuperCard electronics and other electronics. We have revolutionized a new way of tuning vehicles.
We use cell-phone technology to make our small SuperCard chips and boards, allowing us to have a compact unit. This makes it simple for our customers to install, and it works seamlessly with the vehicle; at all throttle positions, all altitudes, all temperatures, all conditions.
To produce a CARB-legal product, it has to work. But we take it a step further and not just pass CARB regulations, we make it so it performs on the track, at full throttle, on the street, idling in traffic.
The SuperCard sees injector duty cycle output and manifold pressure. The SuperCard contains proprietary software that is able to determine proper management for all different types of conditions.
General KraftWerks Kit Information:
-The KraftWerks kits and Rotrex supercharger have a 2 year limited warranty. This warranty is on the KraftWerks kit components and Rotrex supercharger. Rotrex determines supercharger warranty.
-The Base and High-Boost kits are made to be used on completely stock engine components.
-There will be an upgrade path from Base kit to High-Boost kit for MT Fit.
-The High-Boost kit and upgrade will utilize a Hondata Reflash and injectors.
-Any aftermarket cat-back exhaust can be used with the KraftWerks kits.
-Test pipes can be used, but in conjunction with our Injector Upgrade Pack.
-The stock MAP sensor is utilized in both the Base and High-Boost kits. No problems using the stock MAP sensor.
-The KraftWerks kits use a single belt in the system. We have extensively tested this serpentine drive, and have verified its capabilities. There is no slippage when using a KraftWerks drive system. We have had great belt life, and no issues with our belt drive's capabilities. Having a spare belt makes it easier when you decide to change your belt. You can change it instantly, and then order another spare or two from us while you drive around on your fresh new belt.
-We include an automatic tensioner with our kit (stock car uses a manual tensioner) to help increase constant belt tension and reduce belt slipping. The automatic tensioner also increases belt life.
We have had excellent wear (meaning low wear), and have had no belt related issues. But we would expect the customer to change the belt a little more often than stock, because the supercharged belt must work a bit harder.
-Fuel Electronics are always standard with our kits, and require no additional tuning.
-A/C is fully-retained
-Our kits have no check engine lights and are a full bolt-on system. Your factory OBDII system will work as normal with our kit.
-We will confirm international compatibility once our production pieces our available. We will be sending these pieces to Rotrex partners throughout the world to check Right Hand Drive Fit/Jazz. We believe that we should have no problems.Unfortunately, the kit will be available in North America only upon initial release. We will get out international testing complete, and then the kit will be available to all Fit/Jazz owners...
-In order to meet CARB specs, we have used the stock injectors with our SuperCard unit. And these stock injectors have been our big limitation, and we have reached the limit for the little Fit injectors. Remember this is the Base CARB pending kit. This kit is to be used with a stock header and cat.
We will be offering an injector upgrade package for those that want to do a header and cat-delete, and it will work directly with the Base kit. The upgrade pack is plug and play, and is a low $399.99.
We will be releasing a Hondata Reflash package as another option for header/cat-delete Fits. This reflash will add many new features for the Fit, including raised rev limit, removed speed governor, adjusted VTEC, etc. This option will also be upgradeable to the High-Boost kit!
The biggest performance gain you can do for your Base SC Fit is ultra-light wheels and high-performance tires.
The Rotrex Supercharger:
-The Rotrex is small; about the size of the turbo it competes against. It has a traction drive, but is sans the turbine of course.
-The Rotrex drive system is a planetary traction drive system. This patented drive allows the Rotrex to spin to extremely high RPMs. There is some calculated slip in the system, but it is very small. This drive has no cut gears, which allows the Rotrex to be ultra quiet.
-The traction drive system has been tested to over 500,000RPM! Compressors wheels will not live at that RPM though. The smallest Rotrex unit spins at 201,000 RPM all day long!
-It uses the same compressor wheels and housings as its turbo opponents, because the drive system can turn the proper RPMs.
-The Rotrex supercharger pumps its own Rotrex SX100 oil, so there is no need to tap the oil pan or add an oil pump. A small Rotrex reservoir is included, along with a small oil cooler for the Rotrex oil.
-The Rotrex SX100 traction oil should be replaced every 50,000 miles or 2 years. If you are doing some heavy track abuse, I recommend changing the oil more often. The bottle included with the kit will cover your first 50,000 miles or so under normal conditions.
-The ratio in the Rotrex supercharger never varies. The C15-16 and C15-60 superchargers used on the Fit kits have a 12.67:1 drive ratio.
-The supercharger pulley size changes the speed of the Rotrex, just like any other traditional supercharger.
Stock AT (Blue) vs new Fit Auto Base Kit (Red)
Stock MT (Blue) vs new Fit MT Base Kit (Red)
For general kit questions and interest, please email our KraftWerks Sales line!
Kraftwerks Home
Thanks!
-Oscar Jackson Jr.
Old Nov 25, 2008 | 09:01 PM
jeimusu86's Avatar
any chance there will be a group buy for this?
Old Dec 10, 2008 | 02:34 AM
LuxuryMods's Avatar
Wow, I didn't know you guys were so close to me! I'm tempted to come see you for my AT Fit. How much is installation?
Old Dec 10, 2008 | 06:02 AM
kSpec's Avatar
No Christmas special?!
Old Dec 29, 2008 | 07:14 PM
Former Vendor
PM me about local installations!!
Old Dec 30, 2008 | 04:51 AM
kodo's Avatar
whats the price on the AT kit? and do you guys do install to if so how much?
Old Dec 30, 2008 | 01:09 PM
Former Vendor
PMed
-Oscar Jr.
Old Dec 30, 2008 | 03:42 PM
kodo's Avatar
hmmm time to start saving
Old Dec 30, 2008 | 04:29 PM
trancedsailor's Avatar
when will the high-boost MT kit be available?
Old Dec 30, 2008 | 08:07 PM
Former Vendor
Oscar Senior is going to give the big, final thumbs up.... Then we are good to go!
-Oscar Jr.
Old Dec 30, 2008 | 08:27 PM
omg I'm beyond stoked for that *drool* you might make me re-enlist in the navy so I can afford it hahah
Old Dec 30, 2008 | 09:14 PM
Shaggs2Dope's Avatar
Frequent FitFreak Poster
Looks like a super tidy kit. Just sucks even with boost an AT fit is puttin down an AMAZING 110hp. What's the price on the kit and how hard is it to install DIY and tune? CARB certs is a must
Old Dec 30, 2008 | 11:16 PM
J_L's Avatar
J_L
This thing is so freakin' tempting...
Old Dec 31, 2008 | 06:46 AM
SC whine > turbo blowoff ;D
constant power ftmfw!
Old Dec 31, 2008 | 03:56 PM
redrumm's Avatar
install instructions are on the website.
Old Jan 2, 2009 | 11:56 AM
Former Vendor
Correct. Any questions about instructions, they are available on our website as a PDF.
-Oscar Jr.
Old Jan 4, 2009 | 12:46 AM
Hondady's Avatar
will there be a high boost kit for the auto version or are we only getting the 5psi kit? What about a hondata reflash for the auto? It would be nice with the paddle shifters!
Old Jan 8, 2009 | 12:25 PM
Former Vendor
We will not be releasing a High-Boost kit for the Auto Fit.
If we see enough demand for Hondata AT, we would of course look into it. Currently, we have no plans to release Hondata for Fit AT.
Thanks,
Oscar Jr.
Last edited by OJRKraftWerks; Jan 8, 2009 at 06:25 PM. Reason: Adjust my statement...
Old Jan 8, 2009 | 01:42 PM
eldaino's Avatar
We may release Hondata for Auto Fit, if we see enough interest.
Thanks,
Oscar Jr.
oscar i'm sure that EVERYONE rocking the a/t kit will show interest in a hondata version! especially if a highboost kit wont ever surface.
if said hondata version were to come out, would it at leat be boosting higher than the base kit version? maybe like at 6-7 psi?
Old Jan 8, 2009 | 07:58 PM
Koi's Avatar
Koi
Still, you're getting a 20-25% increase in peak HP that you reach earlier, and around 33% increase in peak torque. All this without the trouble of turbo kits, although you can get more power increase from those. From what I understand from those who have this AT kit, it puts the Fit at just the right spot in terms of power - but whether or not the price is justified is of course your opinion. If I had the money for something like this, I'd be rocking it
OJRKraftWerks
1150
Jan 15, 2016 09:40 PM
OJRKraftWerks
542
Nov 14, 2008 07:38 PM
OJRKraftWerks
19
Sep 13, 2008 11:45 AM
OJRKraftWerks
369
May 21, 2008 01:46 PM
OscarJr@JacksonRacing
539
Mar 7, 2008 12:55 PM
