Sponsored by:
Sponsored by: CARiD
HELP! MAP/IAT 4 wire sensor
Old Dec 12, 2008 | 07:43 PM
8valveFit's Avatar
Question HELP! MAP/IAT 4 wire sensor
Do your Honda Fits' have this same MAP IAT sensor ?? Sits right after the throttle body with a 4 wire conector. I know its the MAP IAT sensor but i need to know which wire is the IAT signal wire? 1) green red 5.6volts 2) Yellow red 4.95 volts 3) red yello 4.64volts 4) green white ground
WHich is the IAT signal wire ???
Old Dec 15, 2008 | 11:25 PM
8valveFit's Avatar
Nobody knows ?????????? Dammmmmmmmmmmmmm
Old Dec 19, 2008 | 10:51 PM
explosivpotato's Avatar
USDM GD3 has 2 sensors. The MAP is on the intake manifold log just after the throttle body.
The IAT sensor is in the air box. It sits just before the throttle body.
Old Dec 30, 2008 | 01:55 PM
8valveFit's Avatar
Thanks. . . i know some othger hondas and acuras use the integrated MAP IAT combination sensor but not the USDM fit. Im going to dump my 8 valve motor which is great, for a 2 litre eventually
dasdavid
Apr 15, 2017 02:39 PM
De36
Jun 2, 2016 06:31 PM
Koi
Aug 16, 2010 09:35 PM
NIGHTHAWKSI
Feb 26, 2009 08:57 AM
gthumb23
Oct 18, 2006 01:05 AM
