09 Fit Sport Amp Rating??
Old Dec 21, 2008 | 04:08 PM
madhartigan's Avatar
Does anyone know what kind of amp rating our alternators have in the 09 Sport model?
I'm going to be running 2 amplifiers (1 rated at 120A@1000W and 1 rated at 40A@500W) and I want to be sure I have enough juice and won't have dimming.
If anyone know this information I'd really appreciate it!!
-Darryl
Old Dec 21, 2008 | 04:19 PM
manxman's Avatar
-Darryl
You'll probably have to buy/borrow an ammeter and check your alternator yourself, or have a parts shop do it for you. The Honda Service Manual would have that info., but it won't be available until 03/09. I will buy one the minute that HelmInc. will accept my order.
Old Dec 21, 2008 | 05:58 PM
Thank you for the reply manxman!!
I, too, am waiting for that item to become available. It appears that the item is "In Stock" and then you try to put it in your cart and nothing shows up in the cart. Repeat ad nauseum.
It's a real bummer because when I saw "In Stock" I was psyched.
Oh well, I'll see if I can find an ammeter at my shop.
Thanks again.
ADD: If anyone has the '08 Service Manual, that might say what rating that alternator has and give me an idea as to what's in the '09. I can't imagine they differ too significantly.
ADD2: Well, I just looked at my copy of the 02-05 Jazz/Fit Manual and it says that it's a 12V - 75A Alternator. I can't imagine the '09 is less, but it's probably not too much more either. Guess I'll have to upgrade when I can find a high output that'll "fit."
Old Dec 22, 2008 | 12:33 AM
manxman's Avatar
Thanks again.
When I first started checking in late October, the '09 Fit manual wasn't even listed. So I called the company and was told of the 03/09 publishing date. If they now show it "available", you might try a phone call to get the real story. Maybe they pushed the publishing date up a month or two.
Old Dec 22, 2008 | 08:07 PM
reako's Avatar
Just get a capacitor! I picked up a digital 2 farad (Power Acoustik) even for my humble 300w(RMS) Kenwood/JL 12w3v2 setup! Can't go wrong!!!
Old Feb 6, 2009 | 10:49 AM
Fit317's Avatar
I know for a fact that the 2007 Fit Sports have a 90 amp alternator. And also, For some who installs car audio at a shop, let me tell you that capasitors that are .5- to like 10 are just gonna harm your alternator, since the capacitor that size is nearly instantly discharged on your first bass hit. So then ur alternator is charging the cap and your battery, which strains it. Plus those capacitors are pretty useless. Your lights shouldnt dim much or even at all with a 300 watt amp. Over time the cap with just ruin your alternator. Your WAY batter off running without is.
Old Feb 6, 2009 | 10:51 AM
Fit317's Avatar
Thanks again.
The 07 Sports have a 90amp alternator. I think that the 09's are 90amps too. but ill check for you.
Old Feb 20, 2009 | 09:04 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
i have a 1000w amp on my car and no dimming at
all if that helps.
Old Feb 24, 2009 | 07:27 AM
radareclipse's Avatar
I for one would like to know the proof you have that the 2007 has a 90 amp alternator since I'm the one that sent an alternator to Ohio Generator for testing two years ago and it wasn't 90 amps.
Old Feb 24, 2009 | 07:59 AM
Fit317's Avatar
Well motor alldata say its a 90 and a honda tech told me it was. If hes wrong and the motor all data. Database is wrong then my bad
Imjusthereforadvice
Nov 13, 2018 02:44 PM
Teh_tourist
Aug 15, 2010 10:36 AM
thric3r
Jul 18, 2009 02:38 PM
07FitSBOM
Oct 25, 2008 05:40 PM
russttu
Sep 18, 2008 02:07 AM
