JDM red badge DIY *warning* lots of pics
Old Jan 6, 2009 | 03:57 PM
  #41
NIGHTHAWKSI's Avatar
Originally Posted by Chris901202
Does anyone know the dimensions for the red badges that you've all got?
I'm looking into getting one for my car here in the UK, just need to make sure they'll fit!
Cheers!
the front red badge is maybe 3mm smaller than the one that comes on your car, and the rear is the same size (maybe a mm or 2 larger/smaller...i cant remember)
just measure the H badges that came on your car and base it off that.
Old Jan 15, 2009 | 07:03 PM
  #42
GTI-Jazz's Avatar
Is there a forum topic for this on the GE8?
Old Jan 20, 2009 | 08:29 PM
  #43
Rampage289's Avatar
Is there a different way of doing the front? Or is sanding it the only way?
Old Jan 21, 2009 | 06:17 AM
  #44
braziers's Avatar
I used a different front badge to what most people use.
For the rear I used P/N - 75701-S6M-Z01
And the front I used P/N-75700-SMT-E00
The front badge is the exact fit for the jazz/fit grille.
Its also curved so the only part you have to sand off the grille is the little nobbly bits the old pins went into.
Old Jun 18, 2009 | 04:14 PM
  #45
crabbman's Avatar
Hello,real nice article.
i HAVE A S.S.09.
Will this same product fit as well?
Thank you.
Old Jul 6, 2009 | 02:31 AM
  #46
FLFIT239's Avatar
getting done next week yay
Old Aug 8, 2009 | 11:57 AM
  #47
Fitguy07's Avatar
Yes, pretty much sanding is the only way if you want the emblem to stick right. Not sure of any model Honda out there will work perfect for it or not. I doubt it otherwise Jdmland/icb would of had them.
If you decide to do it without a dremel get very coarse sand paper. I used 3M 60 grit automotive sandpaper. (Green) and it took a little while. If you have the money, get a dremel, if not get some 60 grit or below and some elbow grease.
Old Oct 30, 2009 | 02:22 AM
  #48
ClownCarTuner's Avatar
Great write up man! I give you an A-, I would give you an A+ but you broke stuff. LOL
Old Jan 15, 2010 | 09:26 PM
  #49
123fit's Avatar
Will this write up work for the ge?
Old Jan 15, 2010 | 09:44 PM
  #50
Choro-Q_Fit's Avatar
There's a write up for the GE floating around.
Old Jan 15, 2010 | 10:28 PM
  #51
Btrthnezr3's Avatar
Yea, I want to do mine--I remember the GE thread but haven't seen it in a while.
Hmm...searching...
Old Jan 15, 2010 | 11:09 PM
  #52
123fit's Avatar
Hey I found it here it is in case anyone needs it. https://www.fitfreak.net/forums/2nd-...m-emblems.html
Old Apr 3, 2010 | 06:23 PM
  #53
Klasse Act's Avatar
Thumbs up
I too would like to thank you for the write up and pics
Old Apr 14, 2010 | 03:01 AM
  #54
ViNZx_xD's Avatar
nice DIY dude...
Old Apr 18, 2010 | 06:00 PM
  #55
Scala's Avatar
Thanks for the DIY
Old Apr 19, 2010 | 06:09 PM
  #56
Midnight Run's Avatar
A for effort.
Old Apr 20, 2010 | 04:01 PM
  #57
ivtechFit's Avatar
I think they should make one for all GE8 09-10, and one for Gd3 07-08, so that ppl know where to find them when they need a DIY Thread. it seem like theres not alot for Ge8 thread how to diy to replace your jdm red h emblems?...just my $0.02 cents:}
Old Nov 14, 2010 | 02:30 AM
  #58
shaka808's Avatar
Red H Badges off of eBay + '10 Rear badge -DOESNT FIT!
So i purcahsed Front and Rear RED "H" Badges (JDM) off of eBay. Paid a whopping $80 for them.
Arrived quickly - did all the prep work (cutting off the two tabs, removing grill, cleaning area, etc). Placed them on. Front went on well, the back however is SO OFF (I have a '10 Fit Sport). It's at LEAST 1/4" off because of the curveature. So if you place the rear badge on, you can either have the top part of the H stick or the bottom. I figured the TOP would be best to allow the rain or water to fall over it.
in just TWO DAYS, the badges were falling off. I had to keep on "pushing" them on. Got sick of it, so I removed them (it was SO EASY) , and just removed the 3m tape (which took 30 seconds).
Purcahsed 3m tape from my local NAPA store then redid it myself. I also compensated (added more tape) towards the bottom of the rear badge to take care of the space issue.
It's now SOLID. no movement at ALL.. which is how is suppose to be.
Anyone else have this issue??
Old Dec 8, 2010 | 12:26 AM
  #59
RallyeRedPanda's Avatar
wish i had the cash to do this
looks good!
Old Feb 22, 2011 | 02:39 AM
  #60
Jetzie's Avatar
Guys! May I know where I can order the emblems from? Any online stores or shops? I'm from Singapore and I actually require a Civic ep3 emblem for my 07 Fit.
Many thanks in advance!
