Cargo light upgrade
Old Jan 16, 2009 | 07:21 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
now take the old cargo light and cut all the stuff off the back.
make sure you leave out the parts that is utilizes as the holders.
sorry i don't have any good pics of this. this is the best one i have.
cut it all down to about 1/2 inch
now i cut 2 slots and slid the led under. then as for the other side
i screwed it down. use a very small screw and make sure you pre-drill.
should look like this.
now it's all done. finished product should look like this.
now just so you know the plug you keep seeing at the end of the led is
not going to be used. I cut it and spliced a wire about 3 to 4 feet long
to it.
now run the wire to your cargo light.
Old Jan 16, 2009 | 07:27 PM
niko3257's Avatar
i basically crimped the wires at the top and soldered them at the cargo light.
i choose to solder at the bottom so i can be able to still use the lights with the switch on the cargo light.
sorry no pics of this process either.
but i can tell you the pink wire is + hot wire at the clip on the cargo light.
so now i'm done.
here are all the pics of the final product.
i'm very pleased with the light out put also. it is very bright.
Old Jan 16, 2009 | 07:34 PM
JDM_DOHC_SiR's Avatar
Dang!!!!!>>>.<<<
Old Jan 16, 2009 | 07:37 PM
koolkevin1107's Avatar
damn that's really cleaver! Looks really good and functions amazingly!
Old Jan 16, 2009 | 07:38 PM
TaffetaWhite's Avatar
Someone that spends her life on FitFreak.net
Nicely done, Niko!
Old Jan 16, 2009 | 08:11 PM
dman's Avatar
Another excellent DIY write up!
Old Jan 17, 2009 | 06:51 PM
OneStopCustoms's Avatar
I have Dailed custom made for honda fit lights... They light up the entire cargo plus the outside, its like having a flash light lol.
Old Jan 22, 2009 | 10:40 AM
Delphi99's Avatar
How much does one of those Dailed lights cost? I went to your web site but there's no pricing info.
Also, would it work in a 2009 Fit Sport?
Thanks.
Old Jan 22, 2009 | 11:13 AM
niko3257's Avatar
Thanks.
Most def would work. The only thing you have to consider
is that those work better in the GD's
If you have ever seen a GD you will notice that the light is
angled.
On the GE's the light is not angled and faces down.
This is why I did what I did.
Old Jan 22, 2009 | 11:30 AM
angled.
check your pm's...
Old Jan 22, 2009 | 01:11 PM
2009 map lights sold out, will have a new shipment coming in within two weeks to three weeks.
Old Jan 22, 2009 | 07:18 PM
  #32
aznwizkidz's Avatar
Hi Onestopcustoms.
I was wondering if you could pm the pricing for the LED cargo and map lights! I would like to purchase them! Thanks!!!!!
Btw, nice pictures!!
Old Feb 5, 2009 | 04:47 PM
  #33
Shaggs2Dope's Avatar
Frequent FitFreak Poster
I did a PCB board white led in the OEM GD location and it is bright as hell. They are high output SMT leds too, like 8-10 of them, and you open the rear hatch its super bright like a UFO landing. I use SMT 1watt whenever possible. Gotta take some pics.
I like the way you did yours tho, looks cool
Old Feb 6, 2009 | 12:32 AM
  #34
niko3257's Avatar
yes please post pics when you get a chance
Old Feb 6, 2009 | 02:24 AM
  #35
I took a few pics but it looks way dimmer in the pictures. I should use another camera. Suppressed flash the camera is dim. The straight on pics you can tell its bright as hell
Old Feb 6, 2009 | 11:04 AM
  #36
Dakid's Avatar
so is this just a plug and play?
Old Feb 6, 2009 | 12:03 PM
  #37
niko3257's Avatar
yes and no depending on what your talking about.
can you be more specific on what you think is
plug and play?
Old Feb 6, 2009 | 12:53 PM
  #38
whyzor's Avatar
picture exposures vary a lot and definitely the flash will throw things off. What you need to do is put in the old bulb, take a picture with camera on manual settings (so it doesn't autoadjust for the next picture). Switch in the new lights and take a picture again with the same manual settings as before) Then you have a good comparison.
Old Feb 6, 2009 | 02:40 PM
  #39
Dakid's Avatar
plug and play?
well what modifications are needed to be able to have this light on a switch?
Old Feb 8, 2009 | 12:02 AM
  #40
buy a switched housing from acura from an RDX cargo area, same basic part
here's mine
its a point and shoot, only settings you can really change is flash/no flash
