how much can the AT handle?
Old Jan 29, 2009 | 12:51 AM
keepitpg's Avatar
i love college
im probably gonna go with the T1R turbo kit.. anyone know how much the AT tranny can handle?
i have headers, cat-back, t1r pully.. all adding horsepower..
with the turbo plus the exhaust, will that be too much for the tranny to handle?
lemme know pleaseee
p.s. i wanna be able to dd this setup and weekend lap..
Old Jan 29, 2009 | 12:54 AM
kylerwho's Avatar
spoon fed
felix69 and guiness have the t1r setup with an automatic. neither have dyno numbers but felix is running 8 or 9 psi i believe.
Old Jan 29, 2009 | 12:59 AM
keepitpg's Avatar
i love college
sweet. im just scared because ill probably be looking at 150 whp and i dont wanna blow the tranny..
that would be a bad day haha
Old Jan 29, 2009 | 01:04 AM
kylerwho's Avatar
spoon fed
just stick with the stock 4.5psi or maybe upgrade to 6psi for your daily and you should be fine.
if you decide to track it though you gotta pay to play is the saying with modding cars.
Old Jan 29, 2009 | 01:08 AM
keepitpg's Avatar
i love college
alright cool. and this will last me 15000+ miles?
oh and +rep
Old Jan 29, 2009 | 01:16 AM
kylerwho's Avatar
spoon fed
yeah it should. explosivpotatoe has run a boosted fit for +10,000 but he also has a manual. i wouldnt worry about reliability if you keep the boost lower and dont try experimenting with higher boost settings.
Old Jan 29, 2009 | 01:18 AM
keepitpg's Avatar
i love college
alright thanks! ill stay between 4.5-6 psi. and ill hopefully be safe
Old Jan 29, 2009 | 01:34 AM
kylerwho's Avatar
spoon fed
if you dont plan on going with higher boost then you should get the hks turbo kit or the kraftwerks sc. their tunes are less involved than the t1r
Old Jan 29, 2009 | 01:44 AM
keepitpg's Avatar
i love college
i heard the hks is illegal in california though.. and whats the diff between a turbo and supercharger? arent they pretty much the same?
Old Jan 29, 2009 | 01:49 AM
keepitpg's Avatar
i love college
i heard the hks is illegal in california, and whats the diff between a turbo and an sc? i know theyre similar..
sorry.. internet problems lol
Old Jan 29, 2009 | 01:57 AM
kylerwho's Avatar
spoon fed
turbos connect to the exhaust manifold and run off the exhaust gas which spins the turbine and creates pressure for the intake side. a supercharger runs off a belt that is connected to the crankshaft to create pressure.
here is the break down of all the kits availible
t1r turbo- bigger injectors, cat delete, doesnt pass smog, more tuning, need to wire it.
hks turbo- is carb legal, less tuning, wiring harness is plug in direct with no wiring, but hp numbers are less than the t1r and you need an authorized hks tuner to do any additional tuning.
kraftwerk base kit- keeps cat so it is smog legal but they have not got carb legal yet, hondata reflash for the ecu so no wiring problems. if you are running a full exhaust (header, cat delete, b-pipe, axleback) you will need the injector upgrade package. more power is made by changing the pulley to make more psi and get a new tune.
Old Jan 29, 2009 | 09:48 AM
explosivpotato's Avatar
couldn't have said it better myself. Kuyler's got you covered, listen to what he says.
Btw a tranny cooler is probably a must. The motor will be fine.
Old Jan 29, 2009 | 11:42 AM
keepitpg's Avatar
i love college
thanks guys! and if no certified hks tuner around.. then i should just go with the sc?
and where could i get a tranny cooler?
Old Jan 29, 2009 | 02:58 PM
Spooling's Avatar
HKS kit isn't for AT, its for MT only.
Old Jan 29, 2009 | 03:07 PM
Spooling's Avatar
There are tuners not affiliated with HKS that can still tune the F-Con. So it doesn't need to be certified HKS tuners.
What do you mean by more tuning / less tuning?
Old Jan 29, 2009 | 03:26 PM
eldaino's Avatar
look through the last few pages of the kraftwerks thread and you can find out where to get a tranny cooler.
while the info he gave you was good, it doesnt neccesarily apply.
like /\mentioned, the hks is only for the m/t models.
and the honda ecu upgrade is only available for m/t models for the supercharger. however, kraftwerks is making upgraded injectors for the a/t supercharger, which should bring its power levels close to the t1r.
for all out power, the tr1 kit is the way to go, but its also going to be the most involved as far a installing, tuning etc. and turbos are not as reliable on a/t cars as superchargers are, especially s/c's like the rotrex unit.
if you want more power reliably, the kwsc is the way to go.
Old Jan 29, 2009 | 03:28 PM
keepitpg's Avatar
i love college
ok thanks! +rep! that was helpful
Old Jun 2, 2009 | 05:11 AM
mugen boi's Avatar
Thumbs up
ボルトオンターボキット:FIT(GD3)
there's HKS bolt on turbo kit 4 auto...the link above shows it
Old Jun 9, 2009 | 07:57 PM
DOHCtor's Avatar
Big tranny cooler, AMSoil fluid and Max 6 PSI and it should be fine... Change fluid more often too, Max 25k miles.. :P
Marko!!
Old Jun 13, 2009 | 08:52 AM
ghostfit's Avatar
you shouldn't even worry about how much hp you are making its all about the torque. See if you can find anything about the torque rating for auto trans in your car and then go about the mods remembering to stay below that level. That or see if level 10 transmission can strengthen the transmission. They seem to be the only place that will even touch import transmissions.
