turbos connect to the exhaust manifold and run off the exhaust gas which spins the turbine and creates pressure for the intake side. a supercharger runs off a belt that is connected to the crankshaft to create pressure.
here is the break down of all the kits availible
t1r turbo- bigger injectors, cat delete, doesnt pass smog, more tuning, need to wire it.
hks turbo- is carb legal, less tuning, wiring harness is plug in direct with no wiring, but hp numbers are less than the t1r and you need an authorized hks tuner to do any additional tuning.
kraftwerk base kit- keeps cat so it is smog legal but they have not got carb legal yet, hondata reflash for the ecu so no wiring problems. if you are running a full exhaust (header, cat delete, b-pipe, axleback) you will need the injector upgrade package. more power is made by changing the pulley to make more psi and get a new tune.
__________________
high roller #7
Quote:
Yeah, I was thinking about you when i made that post. You're insane and I say go for it! you'll have the most badass fit ever.
