I need help with hooking up a non-Honda keyless entry
Old Jun 10, 2006 | 09:52 PM
smeister's Avatar
It's a Viper 5000. I need to hook up the 7 wires for the keyless entry and do not know how to hook them up. If anyone has done this please give me some tips. Thanks.
Old Jun 11, 2006 | 12:29 AM
vtecboost's Avatar
read the manual i think its in the manual to wire for negitive trigger. But your looking for the White/green White/Blue wires in the drivers kick for the lock and unlock wires.
Old Jun 11, 2006 | 12:36 AM
xplicitnoize's Avatar
Still need any help!!!
I can help you with this....PM me i you need . I am a electronic car tech.....i do this all the time!
Old Jun 11, 2006 | 05:40 AM
spider2k's Avatar
assuming its the NA fit, this is direct from....directed
12volts white (50A) + ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
Second Ignition N/A
Accessory yellow/black + ignition harness
Second Accessory white/red + ignition harness
Keysense green/white - ign harn or GCM, 40 pin plug, pin 11
Notes: The GCM (Gauge Control Module) is incorporated in the instrument cluster.
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pin 8.
Power Lock white/green - dr kick or GCM, 40 pin plug, pin 9
Power Unlock white/blue - dr kick or GCM, 40 pin plug, pin 10
Lock Motor white/black 5wi fuse box, green 8 pin plug, pin 2
Unlock Motor yellow/black 5wi fuse box, green 8 pin plug, pin 5
Parking Lights+ red/black + fuse box, 14 pin plug, pin 5
Parking Lights- blue - switch or GCM, 40 pin plug, pin 19
Notes: The GCM (Gauge Control Module) is incorporated in the instrument cluster.If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 16 pin plug, pin 5.
Hazards same as turn signal wires
Turn Signal(L) green/red + switch or GCM, 20 pin plug, pin 6
Turn Signal(R) green/yellow + switch or GCM, 20 pin plug, pin 5
Reverse Light green/black + fuse box, 14 pin plug, pin 9
Door Trigger green (D), purple (P) - kick or GCM, 20 pin plg, pins 14, 13
Notes: Use both wires and diode isolate each.
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pins 20 and 9.
Dome Supervision green/red - fuse box or GCM, 20 pin plug, pin 12
Trunk/Hatch Pin green/red - dr kick or GCM, 20 pin plug, pin 16
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pin 7.
Hood Pin green/black - pin sw or SCU, 20 pin plug, pin 18
Notes: The SCU (Security Control Unit) is under the driver side dash.
Trunk/Hatch Release N/A
Factory Alarm Arm white/red - dr kick or SCU, 20 pin plug, pin 4
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm white - dr kick or SCU, 20 pin plug, pin 3
Disarm No Unlock see factory alarm disarm
Tachometer green/orange ac fuse box, 6 pin plug, pin 2
Notes: Can also go to any fuel injector and use the wire that is NOT yellow/black.
Can also go to any ignition coil and use the wire that is NOT black/white or black.
Brake Wire white/black + sw or fuse box, 14 pin plug, pin 4
Parking Brake green/orange - switch or GCM, 40 pin plug, pin 3
Horn Trigger orange - switch or GCM, 14 pin plug, pin 8
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 16 pin plug, pin 2.
hope this helps.ive also been doing this for about 10 years.
Old Jun 11, 2006 | 10:06 AM
smeister's Avatar
thanks
Thanks guys! I do have the directedtech info for the NA Base Fit, but the Viper 5000 manual talks about 87a and open and closed and I don't know what wires it is talking about. I'll check the manual first and look for the
If anyone could tell me exactly what wires from the Viper 5000 goes to which wire on the Honda I would be set heheh.
Old Jun 11, 2006 | 09:34 PM
spider2k's Avatar
ground the violet and violet/black wires.
the green/black goes to white/green
the blue/black goes to white/blue.
the white/black and brown/black are not used for your application.
Old Jun 11, 2006 | 09:37 PM
smeister's Avatar
Thanks for the help! I'll finish it up tomorrow and let you know.
Old Jun 22, 2006 | 07:29 AM
smeister's Avatar
Alright, I finally had time to finish up a few wires. The only problem is I can't seem to set up the alarm. The instructions say to leave one door open and then turn the igition on then off and then hold down the button. It is supposed to chrip after 3 seconds for the first menu but nada. Did I wire something wrong? The alarm also seems like it has no sensitivity and when it is armed I can't even get it to ALARM.
Old Jun 23, 2006 | 12:53 AM
You have to connect the green wire of your main alarm harness to those wires.
"Door Trigger green (D), purple (P) - kick or GCM, 20 pin plg, pins 14, 13
just be sure that you connected every wires you need to connect.
Also maybe you've enter the Valet Mode by mistake and you can't go in programmation mode while you're in Valet Mode. To get in or out of valet mode you have to put ignition on and then off and then press the little black switch one time.
Have Fun !!!
Old Jun 23, 2006 | 06:44 AM
smeister's Avatar
Have Fun !!!
Ok, I diode isolated two door trigger wires from the alarm to only the green door trigger on the car. I left the purple (passenger) one alone. Also, what does Ignition on mean? Do I turn the key like I was starting the car without the clutch being down? TIA
Old Jun 23, 2006 | 04:21 PM
Ignition on is the position of the key when all the lights come's on in the dash without starting the car.
Old Jun 24, 2006 | 07:51 AM
spider2k's Avatar
how did you isolate them? did you just put a diode between each line and the green or did you cut each wire and put 2 diodes on each one?
Old Jun 24, 2006 | 11:23 AM
smeister's Avatar
I cut the honda wire and put 2 diodes on each of the door trigger wires on the alarm.
Old Jul 7, 2006 | 04:37 PM
Sol705's Avatar
Question, doesn't doing this void the warranty? The dealership was very specific about not installing any components on my own (I guess similar to the
"warranty void if seal broken" stickers)
Old Jul 7, 2006 | 04:48 PM
spreadhead's Avatar
No it won't void your warranty. However your warranty will not cover anything you damage doing the install. The stealership just wants more of your money.
Old Jul 7, 2006 | 04:51 PM
Sol705's Avatar
Is there a number or something I can call to double check this? I'm not too keen on them sharging me $500 to install a POS car alarm that won't even have keyless entry
cuban8
Aug 15, 2018 09:13 AM
doctor J
Nov 27, 2017 02:20 PM
jpcerone
Jan 20, 2015 08:12 AM
dthdabomb89
May 23, 2011 11:16 PM
ex99125b
Jan 17, 2009 10:45 PM
