Painted Stock Wheels
Old Feb 21, 2009 | 05:02 PM
Fitcapo's Avatar
Alright well since everyone keeps opening new threads on painted stock wheels I figured the hell with it I will just make a thread and post up all of the pictures I can find on it and hopefully I can get one of the mods to sticky this.
Please contact me or post up picks of your painted stockers if you have them or find them.
Old Feb 21, 2009 | 08:21 PM
YA2_user_GD3's Avatar
Fitcapo is my home-boy.
Old Feb 21, 2009 | 08:28 PM
B1str0's Avatar
RubberBabyBuggyBumpers
those purple ones are sex im doing my blades purple and im gonna put them on my girls car (when she gets one) lol
Old Feb 21, 2009 | 09:45 PM
Type 100's Avatar
The bronze ones are quite nice too! Bronze and black definitely work for repainted stock Fit wheels.
I wonder if someone's brave enough to paint 'em light gold.
Old Feb 21, 2009 | 09:49 PM
solbrothers's Avatar
painted wheels are cool, but id rather sell the stockers and get slips or something
Old Feb 21, 2009 | 10:08 PM
stole this from honda-tech.com http://honda-tech.com/showthread.php?t=1356908
Since this topic has been popping up a lot lately, I decided to write up on painting wheels I did for my winter wheels.
Everything I used can be found in your local automotive parts store.
Materials
· Paint stripper + brush (that withstands the stripper)
· Wire brush
· Sandpaper (120-2000grit)
· Scuff pad
· Primer (optional)
· Paint
· Clearcoat
· Gloves
· Masking tape
· Blue shop towel
· Tack cloth
· Acetone
· Sanding Mask
· Spray can gun adapter (optional)
· Beer (optional)
· TIME AND PATIENCE
Some materials are not pictured
Wheel (OEM Integra)
Paint stripper (BIG container, not spray can)
READ THE INSTRUCTIONS ON PAINT STRIPPER CAN BEFORE USE!
Step One: Strip
Removing existing paint and clearcoat on wheel
PROTECT EYES AND SKIN FROM PAINT STRIPPER AT ALL TIMES
1. Pour the paint stripper in a metal can (I used a soup can). Dip the brush in can.
Start applying the stripper slowly with brush. DO NOT RUSH THIS STEP
2. The paint and clearcoat should start bubbling up shortly.
3. Set a timer to 20 minutes.
4. While you wait......
Step Two: Scrub
Scrubbing off paint and clearcoat. This will ensure you not to repeat step one.
1. Grab a wire brush (I used stainless steel)
2. Start scrubbing. Watch your eyes!!
3. Pressure wash off the remaining residue and air dry.
Step Three: Sand
Sanding down area that you wish to polish. Skip this step if you do not wish to polish.
1. Dry sand starting with 120 or 180grit if you have deep scratches and/or curb marks. If there is no damage start from 220grit. Work your way up to 320, 400, 600.
Here's how it looks after 120-400 (I sanded the lip only)
2. Wet sand starting with 600grit working up to 800, 1000, 1500, 2000. Use lots of water.
After wet sanding...
Step Four: Prep
Masking down area that will not be painted and scuffing.
1. Mask the area you polished and/or you do not wish to paint by using masking tape (I used green and blue, both by 3M)
2. Scuff down the area that will be painted with a scuffing pad. Take your time and make sure surface looks even.
3. Slightly wet 1/8 of a blue shop towel with acetone and start wiping down the scuffed area. Finally, wipe down with tack cloth to get every last piece of lint the towel left off.
Step Five: Primer
Spraying primer(optional). If you do not wish to use primer you may skip to the next step. You can use sandable primer, primer sealer, etc...
1. Make sure all surroundings are covered/masked unless you do not mind paint everywhere. Spray light coats. The first coat of primer should not fully cover the wheel.
After first coat of primer (I used primer sealer).
2. Wait 5 minutes, spray second coat. Again, lightly.
3. Wait 5 minutes, by now you can see the wheel is almost fully covered expect a few spots (depending on design of wheel). Lay down final coat of primer.
4. Let the wheel sit for about 15-20 minutes. If you used sandable primer, you may sand it down after it dries.
Step Six: Spray
Spraying paint and clearcoat.
1. Lay down first coat of paint. Several light coats to avoid runs and overspray. Spray in a sweeping motion (While pulling trigger move left, release. While pulling trigger move right, release. Repeat.)
After first coat..
2. Wait 10 minutes, lay down second coat.
3. Wait 10 minutes, lay down third coat.
4. Wait 10 minutes, inspect. At this point, if the wheel is evenly covered with paint you may stop and let it dry. If not, lay down another coat and call it final.
5. After final coat, color should look even across the wheel. Let it dry for 30 minutes before laying down clear.
While you wait..........
6. Lay down clearcoat just like painting. But you may use several medium coats instead of light coats to pull out more shine. Don't go crazy with it!!
(Sorry, no pictures of spraying clear)
Step Seven: Dry
Drying your work. Most overlooked process when painting at home. Failure to proper drying may result in repeating a lot of work.
1. After the final coat of clear, let it sit about 30 minutes before you transfer them to a cleaner safer place to air dry overnight.
2. Dry it overnight indoors.
Step Eight: Final Outcome
Inspect for damage and flaws under the sun. If you satisfied with the results, kickback, grab a beer, a blunt, a dutch, a L, a joint, whatever you want, and admire your work. Just don't forget you got 3 more to go.
1. Pull off the masking tape slowly. Be paitent!!!
Optional Step: Polish
If you want that polished area to really shine, metal polish (mother's stuff works great), a polisher and/or power mini ball. Buff it up. Read instructions on metal polish.
Optional Step: Shine
Now you polished the metal so good the paint starting to look dull?
You can wet sand your clearcoat with 1500-2000grit sand paper to get a smooth even texture on the painted area. You can also polish the painted area with a rubbing compound, polishing compound, followed by wax.
This is not required but you may do it down the road once the paint fully cures. Give it about 2-3 weeks.
I didn't do the optional steps since these wheels are going to be hitting snow and salt 24/7.
As long as you have some common sense and know how to read, this job won't be a problem. Hope this helps the folks that PM'd me about this info.
Maintenance
Poor maintenance can make your wheels look worthless real quick.
For the first week just wash them down with low pressure water.
After that, wash your wheel separately when you wash your ride.
I use soap water but you can use your favorite wheel cleaner.
SOAK IT, BUT DON'T LET THE CLEANER/SOAP DRY OUT
You may start buffing after they dry.
For painted areas,
pick your favorite rubbing compound and/or polishing compound followed by wax.
For polished areas,
pick your favorite metal polish followed by wax.
Polishing might not be necessary for every car wash.
You can re-polish them once a month or whenever they get dirty or dull.
Both buffing steps can be done by hand but I recommend a buffer/polisher and powerball mini (works great on lips) for the best results.
Don't forget about the tires, get your favorite tire wetter and let 'em shine!!
Old Feb 21, 2009 | 11:20 PM
Fitcapo's Avatar
I think that is a little overkill but will definately work.
Old Feb 22, 2009 | 12:10 AM
its idiot proof. better to prepare for the idiots then to not at all. very well done!
Old Feb 22, 2009 | 12:29 AM
why overkill? kicks the shit out of spray on some "wheel paint" and then complain about it chipping a week later. just as in painting a car, its all in the prepwork
Old Feb 22, 2009 | 12:32 AM
Fitcapo's Avatar
I just sanded my wheels down cleaned them off with soap and water then wiped them down with rubbing alcohol and sprayed and they have held up great so far and it has been through a summer and a pretty rough winter.
Old Feb 22, 2009 | 12:38 AM
fitster's Avatar
thats what i did when i painted my stockers
just no aircraft stripper
went streight to sanding
Old Feb 22, 2009 | 12:39 AM
ur wheels are fairly new, very easy to paint. those ls wheels, its better to be safe than sorry. also this method works period on any wheel. ur method altho great doesnt really work on super old wheels with more than just dirt and a few scratches. not trying to say ur method was bad or anything but solbrothers has a point about prepwork.
aircraft stripper is great for old wheels wit tons of crap thats like edged into the stuff.
Old Feb 22, 2009 | 12:41 AM
honestly, the results you get reflect the prep work.
Old Feb 22, 2009 | 12:48 AM
yea, they might not chip but as soon as they hit something a little hard, let the chipping begin! prepwork will ensure a highly durable coat with minimal scratch/chip.
Old Feb 22, 2009 | 03:18 AM
kodo's Avatar
Here mine painted but never mounted i just sold it lol way back ago.
Have white Koning Heliums right now but waiting on my wedsport to come should be here next month.
Old Feb 22, 2009 | 10:26 AM
Gbaby2089's Avatar
wow sol that was a nice how-to that you found
Old Feb 22, 2009 | 01:39 PM
thanks gbaby. hondatech ftw!!!!!!!!!!!!!!
Old Feb 22, 2009 | 02:03 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
yeah matt that how to was amazing
Old Mar 13, 2009 | 07:15 PM
Shaggs2Dope's Avatar
Frequent FitFreak Poster
One of the cleanest lookin OEM rim-jobs. The difference is in the Details. The gold with polished lip looks clean, but I want a set of meshies like this, just swap the center caps for Honda ones. Or leave the lip polished and do inside spokes gunmetal or flat black
You are gonna still see more of these threads in the future. It's a cheap way to change the look of your car while still lookin stock/oem and get a color scheme going. With the economy as shitty as it is, people will be spending less money on buyin new rims and just changing the ones they have to make it feel fresh or new. Changing one part with other parts keeps a car feelin new a long time. All in the rotation.
Old Mar 13, 2009 | 07:53 PM
trancedsailor's Avatar
sure the face looks good, but behind it looks like ass? Nothing in the steps talks about flipping over the wheel to do the backside...my Enkeis are horribly painted and chipping like hell. I'm gonna get them powdered eventually. Screw painting them yourself. It's simply not as quality as professional powder.
