ultra racing 4pt lower brace..install
Old Feb 24, 2009 | 12:27 AM
redrumm's Avatar
thanks yo
Old Feb 24, 2009 | 02:59 AM
LiL Wee FIT's Avatar
So no drilling was required? The only thing that needs 'modification' is that some spacers are needed to keep the bar secured?
Old Feb 24, 2009 | 03:07 AM
redrumm's Avatar
no drilling. it bolts you just need like 3 spacers and bolt it into the body.
Old Mar 5, 2009 | 08:51 AM
redrumm's Avatar
got my front under brace in and will be installing that maybe saturday
Old Mar 7, 2009 | 12:11 AM
Kurse's Avatar
whats your suspension?
i've see the sway bay of ultra racing, it look nice too
Old Mar 7, 2009 | 12:42 AM
redrumm's Avatar
megan coilovers
ultra racing JDM room bar
ultra racing rear strut bar
ultra racing front strut bar
ultra racing 4pt rear lower brace
ultra racing 4pt front lower brace(install tomorrow)
ultra racing fender bars(on its way)
Old Mar 7, 2009 | 01:05 AM
kylerwho's Avatar
spoon fed
that is just enough bracing so that you can drop in a k20.
Old Mar 7, 2009 | 11:26 AM
redrumm's Avatar
yeah it would be nice. the place my friend goes to get tuned said the guy makes custom cages and i should ask to see if he could fab me one.
there making one on a corvette that cost $11,000 haha
kinda want a roll bar
Old Mar 7, 2009 | 12:50 PM
dewthedew's Avatar
does the front fit without mods?
Old Mar 7, 2009 | 10:00 PM
koolkevin1107's Avatar
that's what i'm waiting on too, but from what i read, the front one is 2-3 inches too long.
Old Mar 7, 2009 | 10:11 PM
redrumm's Avatar
i didnt have a chance today to throw it on so tomorrow i will take a look at it and let you guys know
Old Mar 8, 2009 | 05:03 PM
  #32
FELIXY69's Avatar
Originally Posted by redrumm
today i installed the ultra racing 4pt lower brace and it feels really good. it definately tightened up the back end a lot. It was really easy to install and even though it doesnt sit flush with the underbody, i had some plates made so it would fit. ( you can use washers also)
first you want to start by taking out the bolts. when your done doing that, bolt in the back ones leaving them loose enough to move the brace around
here is the plate. you can use washers to make it sit flush. it barely fit with the plates.
line up the holes and tighten the bolts in the front( i know the right side is not done in the pic) and this is how it looks all done. then test drive and feel that tight ass
wow the bottom of ur car is VERY clean !!!....and looks likea good day out to work on urr car !
i think i am going to attempt to put mine on ....
u figure out the front yet btw ?
Old Mar 8, 2009 | 07:59 PM
  #33
redrumm's Avatar
yeah no snow in san antonio haha.
its really easy man to put in,
just leave the back bolts loose enough to were you can align the front.
bolt the front in and then go to the back ones and bolt those in.
a few washers will make it flush
working on the front one as we speak
Old Mar 8, 2009 | 09:20 PM
  #34
redrumm's Avatar
welp the front brace is a NO GO.
it deff doesnt fit. the bar is a few inches too long from its mounting point.
so here is the line up
front strut bar fits
rear strut bar fits
C pillar bar fits
rear lower bar fits with washer mod
front lower brace does not fit(few inches too long)
fender braces are on there way
Old Mar 8, 2009 | 09:38 PM
  #35
rear strut bar fits
C pillar bar fits
Damn that sucks that the front doesn't fit. U wouldnt happen to have any pix of it not fitting would ya? I'm wondering if i could cut off the part of the bracket that is too long and re-weld them to fit. Do the bolts line up at least, just too far forward?
Old Mar 8, 2009 | 10:55 PM
  #36
redrumm's Avatar
no i dont. you could if you wanted too. you could drill a hole where it needs to be mounted but it would be hard to get a bolt in the 2 little holes
Old Mar 9, 2009 | 12:33 PM
  #37
FELIXY69's Avatar
  #38
FELIXY69's Avatar
thx for testing it out for us !!!
Old Mar 10, 2009 | 10:17 PM
  #39
redrumm's Avatar
not sure man, probably has to do something with the US car being longer or something
im making a thread on the other one
Old Mar 13, 2009 | 05:48 PM
  #40
Kurse's Avatar
which sway bar are the best between the UR-AR16-035 and the UR-AR16-139?
