Help! My radio stopped working !
Old Feb 26, 2009 | 10:07 PM
GodSpeed's Avatar
So I'm driving the other day and out of nowhere my radio stops working! I pulled it out to make sure all the connections where good, and, even though I know its still getting power because when I push the eject button the CD ejector makes noise, I checked the fuses, and they are all good. Any ideas ? Please help I miss my music...
BTW its an 07 base with the stock radio and speakers
Old Feb 26, 2009 | 10:26 PM
Rubba Burna's Avatar
HID Addict
hmm you do realise, that unplugging the power "locks it down", security feature for anti-theft. When you bought the car, you were givin a 5 digit radio code. look in ur manual or some documents for this code. the digits are 1 thru 6. This feature not only locks down teh "radio" aspect, but the CDand AUX as well. thats what it sounds like to me... if your car lost power, like the battery died or something, than thats y, definatly if you unplugged it from the car itself heh. BTW, i drive a sport 08, but i would assume that the 07 is the same.. i could be wrong -shrugs-
Old Feb 27, 2009 | 12:39 PM
NIGHTHAWKSI's Avatar
i think the OP only unplugged his radio AFTER it stopped working.
bring it to the dealer...the radio is a warrenty item. as long as your under 36k.
if your not under warrenty.....
recheck your fuse. sometimes it doesnt look bad , but it is. try adn replace it anyway
make sure you have your radio code as Rubba mentioned, disconnect your negative terminal from the battery for a few seconds and it might fix it.
Old Feb 27, 2009 | 08:28 PM
GodSpeed's Avatar
Ill try the negative disconnection thing tomorrow. I know is not the radio code because when the radio needs the code to operate it says ENTER CODE on the screen. My screens not even lighting up. Thanks for the help.
Old Feb 27, 2009 | 09:08 PM
HID Addict
not even lightin up? hmm, now THATS wierd... i highly recomend takin that to a dealer
Old Feb 28, 2009 | 12:01 AM
Jazz GD3's Avatar
check out the [back-up] fuse in the engine compartment fusebox.
Old Feb 28, 2009 | 12:48 PM
GodSpeed's Avatar
Could it still be a fuse even though the CD ejector is working ?
Old May 17, 2009 | 11:47 PM
carlosalicea's Avatar
hey ...... I know somebody said in some post long ago that the code is somewhere in the car to be found. My battery died today and I pushed start the car, but then I get the code and I dont find my car documents anywhere (sinceI moved).
Please someone tell me whaere to find it!!!!
My sport has 88,500 miles and pushing hard!!!!!!!
Old May 17, 2009 | 11:57 PM
713_fit's Avatar
go to dealership
they can get the code for you
Old May 18, 2009 | 12:18 PM
im the fit's Avatar
the code is in the glove compartment
Old May 18, 2009 | 06:06 PM
713_fit's Avatar
it should be
or with your manuals
but if you lost them all
just call the dealership you brought it from..they should have your code by vin number...if not..they can pull it up by serial number from the radio
Old May 19, 2009 | 09:34 AM
Originally Posted by 713_fit
it should be
Thanks everyone. I found the documents from when I first got the Fit!! i even got the widow japanese labels and stuff. there was the card.
Thanks 713_fit. I knew that ia had read something like that in the past.
In a strange subject, the battery just charged ...... @#$%^!!!! I think it's a wake up call.... time to see where to find that Odyssey lightweight battery!!!! in Puerto Rico
Indy62
Feb 23, 2015 10:53 AM
SilverEX15
Aug 19, 2014 08:25 PM
Duhvidx
Sep 5, 2013 01:30 AM
mikelowell915
Sep 1, 2012 08:35 PM
paulf5164
Sep 9, 2007 10:44 AM
